Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM3S5C56-IQR80-A2T — Даташит
СерияLM3S5C56
МодельLM3S5C56-IQR80-A2T
Микроконтроллер Stellaris LM3S 64-LQFP от -40 до 85
Stellaris LM3S5C56 Microcontroller Data Sheet datasheet
PDF, 6.2 Мб, Версия: C, Файл опубликован: 3 июл 2014
Pin6464
Package TypePMPM
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаLM3S5C56IQR80
Width (мм)1010
Length (мм)1010
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
  • USB Certification for Stellaris-Based USB Peripherals and Embedded Host Systems
    PDF, 3.9 Мб, Файл опубликован: 7 июл 2009
    This application note describes the USB-IF certification process for a USB full-speed device and a USB full-speed embedded host system using the a Stellaris LM3S5732 microcontroller as the example.
Серия: LM3S5C56 (2)
LM3S5C56IQR80A2T, LM3S5C56 IQR80 A2T
На английском языке: Datasheet Texas Instruments LM3S5C56-IQR80-A2T
