Datasheet ATSAM3A4CA-CU - Atmel Даташит Микроконтроллеры (MCU) BGA100, GREEN, IND TEMP, MRL А — Даташит
Наименование модели: ATSAM3A4CA-CU
![]() 26 предложений от 17 поставщиков Микросхема Микроконтроллер, MCU 32Bit SAM3A ARM Cortex M3 RISC 256KB Flash 1.8V/2.5V/3.3V 100Pin LFBGA | |||
ATSAM3A4CA-CU Rochester Electronics | от 80 ₽ | ||
ATSAM3A4CA-CU Rochester Electronics | от 597 ₽ | ||
ATSAM3A4CA-CU Atmel | от 2 337 ₽ | ||
ATSAM3A4CA-CU Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) BGA100, GREEN, IND TEMP, MRL А
Features
· Core
ARM® Cortex®-M3 revision 2.0 running at up to 84 MHz Memory Protection Unit (MPU) Thumb®-2 instruction set 24-bit SysTick Counter Nested Vector Interrupt Controller Memories From 256 to 512 Kbytes embedded Flash, 128-bit wide access, memory accelerator, dual bank From 32 to 100 Kbytes embedded SRAM with dual banks 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines Static Memory Controller (SMC): SRAM, NOR, NAND support.
NAND Flash controller with 4-kbyte RAM buffer and ECC System Embedded voltage regulator for single supply operation POR, BOD and Watchdog for safe reset Quartz or ceramic resonator oscillators: 3 to 20 MHz main and optional low power 32.768 kHz for RTC or device clock. High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz Default Frequency for fast device startup Slow Clock Internal RC oscillator as permanent clock for device clock in low power mode One PLL for device clock and o
- Шина данных: 32 бит
- RoHS: да
ATSAM3A4CACU, ATSAM3A4CA CU
