Datasheet Texas Instruments TMS320F28063PNT — Даташит
СерияTMS320F28063
МодельTMS320F28063PNT
Микроконтроллер Piccolo 80-LQFP от -40 до 105
TMS320F2806x Piccoloв„ў Microcontrollers datasheet
PDF, 2.1 Мб, Версия: F, Файл опубликован: 22 мар 2016
Pin8080
Package TypePNPN
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY119119
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320F28063PNT
Width (мм)1212
Length (мм)1212
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC16,12 Ch
ADC Resolution12-bit
CAN1
CPUC28x
Comparators3
DMA6 Ch
FPUYes
Flash128 KB
Тактовая частота90 МГц
High Resolution PWM8,6 Ch
I2C1
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM16,14 Ch
Pin/Package100LQFP, 80HTQFP, 80LQFP
QEP2,1
RAM68 KB
SPI2
Total Processing90 MIPS
UART2 SCI
USB1
  • Evaluation Modules & Boards: BOOSTXL-BUCKCONV
    Digital Power Buck Converter BoosterPack
  • Evaluation Modules & Boards: TMDSCNCD28069ISO
    Piccolo TMS320F28069 Isolated controlCARD
  • Evaluation Modules & Boards: TMDSDOCK28069
    F28069 Piccolo Experimenter Kit
  • Development Kits: TMDSCNCD28069
    F28069 Piccolo controlCARD
  • Evaluation Modules & Boards: LAUNCHXL-F28069M
    InstaSPIN-MOTION (and InstaSPIN-FOC) enabled C2000 Piccolo LaunchPad
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • The TMS320F28004x MCU: A Comparison to the TMS320F2806x and TMS320F2803x MCUs
    PDF, 269 Кб, Файл опубликован: 22 июн 2017
    The Texas Instruments Piccoloв„ў TMS320F28004x microcontroller (MCU) device series offers an optimal balance between performance and cost for many real-time control systems. This document discusses the technical details of the TMS320F28004x architecture and highlights the new improvements to various key peripherals, such as an enhanced Type-2 CLA capable of running a background task, and the i
  • Using the CAN Piccolo Bootloader at High Temperature
    PDF, 33 Кб, Файл опубликован: 29 июн 2015
    The Controller Area Network (CAN) protocol requires strict tolerances from reference bit clocks, which are generally met using quartz crystal oscillators or ceramic resonators. The TMS320F2803x, TMS320F2805x, and TMS320F2806x microcontrollers use an on-chip zero-pin oscillator with no external components as a reference clock for the CAN bootloader. This oscillator's tolerance is sufficient at room
  • Piccolo TMS320F2802x/2803x Migration to TMS320F2806x
    PDF, 105 Кб, Файл опубликован: 1 мар 2011
    This application report describes differences between Texas Instruments' TMS320F2802x/2803x and TMS320F2806x microcontrollers to assist in application migration. While the main focus of this document is migration from 2802x/2803x to 2806x, this document is also useful if you are considering migrating in the reverse direction. Functions that are identical in both devices are not necessarily include
  • Getting Started With TMS320C28x Digital Signal Controllers (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 25 окт 2007
    This guide is organized by development flow and functional areas to make your design effort as seamless as possible. Tips on getting started with TMS320C28xв„ў DSP software and hardware development are provided to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, software, and tools for use in each phase of d
  • TMS320C28x FPU Primer (Rev. A)
    PDF, 228 Кб, Версия: A, Файл опубликован: 20 июл 2009
    This primer provides an overview of the floating-point unit (FPU) in the C2000в„ў Delfino microcontroller devices.
  • Power Line Communication for Lighting Apps using BPSK w/ a Single DSP Controller
    PDF, 1.7 Мб, Файл опубликован: 7 мар 2006
    DSP controllers provide the on-chip peripherals and computational power needed to implement various power electronics applications. A single-chip DSP controller allows designers to implement multiple functions such as power line communication, power-factor correction, and inverter control, all needed for an overall dimmable lighting ballast application. This application report presents a complete
  • Configuring Source of Multiple ePWM Trip-Zone Events
    PDF, 93 Кб, Файл опубликован: 25 окт 2007
    Applications that require PWM outputs to respond to multiple trip-zones (TZ) are challenged to determine the specific source of the TZ event.This application report describes how to configure an ePWM module to identify the specific source of a TZ event when multiple TZ events are enabled to act on a single PWM channel.
  • InstaSPIN(tm) BLDC Lab
    PDF, 1.4 Мб, Файл опубликован: 15 ноя 2011
    For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU (DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo F28035 controlCARD subsystem to run the sensorless InstaSPIN BLDC technique.These are the tasks that must be done to spin motors:Make sure all physical connections and jumper settings on the kit
  • Custom Bootloader Options via One-Time Programmable (OTP) Memory
    PDF, 62 Кб, Файл опубликован: 18 сен 2007
    The Boot to One-Time-Programmable (OTP) memory mode in the TMS320x280x devices provides the necessary hooks to support custom bootloaders. This is very useful in a situation where a bootloader option, required by a specific customer application, is not already supported as one of the built-in options in the Boot read-only memory (ROM). This application report includes information and examples on h
  • Interfacing SD/MMC Cards With TMS320F28xxx DSCs
    PDF, 1.3 Мб, Файл опубликован: 26 июл 2007
    This application report and associated code implements the interfacing of Secure Digital (SD) or Multi-Media Card (MMC) types of Flash memory cards with the TMS320F28xxx digital signal controllers (DSCs). These cards can use serial peripheral interface (SPI) or parallel (SD) interface to connect to the host. This application report demonstrates the SPI mode and includes the schematics showing th
  • An Easy Way of Creating a C-callable Assembly Function for the TMS320C28x DSP
    PDF, 185 Кб, Файл опубликован: 30 окт 2001
    C-callable assembly routines require an understanding of parameter-passing conventions and environments expected by the C compiler. This application report provides instructions and suggestions to configure the C compiler to assist with these issues.
  • An Overview of Designing Analog Interface With TM320F28xx/28xxx DSCs (Rev. A)
    PDF, 655 Кб, Версия: A, Файл опубликован: 14 май 2008
    This application report provides guidelines that take you through everything from configuring the ADC and related registers correctly, responding to interrupts, and board design recommendations; this may be particularly useful for first-time users of the TMS320C2000в„ў digital signal processor (DSP) platform devices and for firmware engineers with less exposure to the analog world. Various s
  • Copying Compiler Sections from Flash to RAM on the TMS320F28xxx DSCs (Rev. A)
    PDF, 307 Кб, Версия: A, Файл опубликован: 18 авг 2017
    This application report and associated code files provide functionality for copying initialized compiler sections from the internal Flash memory to the internal random access memory (RAM) of the TMS320F28xxx digital signal controllers (DSCs) at run time for optimizing execution speed. The solution provided implements this functionality directly after booting before entering the c_int00 C entry rou
  • Online Stack Overflow Detection on the TMS320C28x DSP
    PDF, 407 Кб, Файл опубликован: 2 май 2003
    A stack overflow in an embedded DSP application generally produces a catastrophic software crash due to data corruption, lost return addresses, or both. Traditional off-line approaches to sizing a stack during development, such as filling with a know value, or estimating based on code content, are not 100% reliable. Therefore, programmers often feel compelled to reserve larger stack sizes than are
  • Using PWM Output as a Digital-to-Analog Converter on a TMS320F280x (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 9 сен 2008
    This application report presents a method for utilizing the on-chip pulse width modulated (PWM) signal generators on the TMS320F280xв„ў family of digital signal controllers as a digital-to-analog converter (DAC). The method involves analog low-pass filtering the PWM signal to remove high frequency components, leaving only the low-frequency content. Theoretical and experimental results are presented
  • Programming Examples for the TMS320x28xx eCAN (Rev. B)
    PDF, 73 Кб, Версия: B, Файл опубликован: 12 сен 2017
    The TMS320x28xx series of Microcontrollers/Digital Signal Controllers feature an on-chip enhanced Controller Area Network (eCAN) module. This module is a full-CAN controller, compliant with CAN specification 2.0B. This application report contains several programming examples, supplemental to those in C2000Ware/controlSUITE, to illustrate how the eCAN module is set up for different modes of operati
  • Running an Application from Internal Flash Memory on the TMS320F28xxx DSP (Rev. L)
    PDF, 641 Кб, Версия: L, Файл опубликован: 28 фев 2013
    Several special requirements exist for running an application from on-chip Flash memory on the TMS320F28xxx. These requirements generally do not manifest themselves during code development in RAM since the Code Composer Studioв„ў (CCS) debugger can mask problems associated with initialized sections and their linkage in memory. This application report covers the application software modificatio
  • Flash Programming Solutions for the TMS320F28xxx DSCs
    PDF, 423 Кб, Файл опубликован: 19 авг 2008
    Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the
  • Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)
    PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
    This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed.
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
На английском языке: Datasheet Texas Instruments TMS320F28063PNT
