Datasheet ТI TMS320F28066PFPS — Даташит
| Серия | TMS320F28066 |
| Модель | TMS320F28066PFPS |
Микроконтроллер Piccolo 80-HTQFP от -40 до 125
TMS320F2806x Piccoloв„ў Microcontrollers datasheet
PDF, 2.1 Мб, Версия: F, Файл опубликован: 22 мар 2016
- The TMS320F28004x MCU: A Comparison to the TMS320F2806x and TMS320F2803x MCUsPDF, 269 Кб, Файл опубликован: 22 июн 2017
The Texas Instruments Piccoloв„ў TMS320F28004x microcontroller (MCU) device series offers an optimal balance between performance and cost for many real-time control systems. This document discusses the technical details of the TMS320F28004x architecture and highlights the new improvements to various key peripherals, such as an enhanced Type-2 CLA capable of running a background task, and the i - Using the CAN Piccolo Bootloader at High TemperaturePDF, 33 Кб, Файл опубликован: 29 июн 2015
The Controller Area Network (CAN) protocol requires strict tolerances from reference bit clocks, which are generally met using quartz crystal oscillators or ceramic resonators. The TMS320F2803x, TMS320F2805x, and TMS320F2806x microcontrollers use an on-chip zero-pin oscillator with no external components as a reference clock for the CAN bootloader. This oscillator's tolerance is sufficient at room - Piccolo TMS320F2802x/2803x Migration to TMS320F2806xPDF, 105 Кб, Файл опубликован: 1 мар 2011
This application report describes differences between Texas Instruments' TMS320F2802x/2803x and TMS320F2806x microcontrollers to assist in application migration. While the main focus of this document is migration from 2802x/2803x to 2806x, this document is also useful if you are considering migrating in the reverse direction. Functions that are identical in both devices are not necessarily include - Getting Started With TMS320C28x Digital Signal Controllers (Rev. A)PDF, 240 Кб, Версия: A, Файл опубликован: 25 окт 2007
This guide is organized by development flow and functional areas to make your design effort as seamless as possible. Tips on getting started with TMS320C28xв„ў DSP software and hardware development are provided to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, software, and tools for use in each phase of d - TMS320C28x FPU Primer (Rev. A)PDF, 228 Кб, Версия: A, Файл опубликован: 20 июл 2009
This primer provides an overview of the floating-point unit (FPU) in the C2000в„ў Delfino microcontroller devices. - Power Line Communication for Lighting Apps using BPSK w/ a Single DSP ControllerPDF, 1.7 Мб, Файл опубликован: 7 мар 2006
DSP controllers provide the on-chip peripherals and computational power needed to implement various power electronics applications. A single-chip DSP controller allows designers to implement multiple functions such as power line communication, power-factor correction, and inverter control, all needed for an overall dimmable lighting ballast application. This application report presents a complete - Configuring Source of Multiple ePWM Trip-Zone EventsPDF, 93 Кб, Файл опубликован: 25 окт 2007
Applications that require PWM outputs to respond to multiple trip-zones (TZ) are challenged to determine the specific source of the TZ event.This application report describes how to configure an ePWM module to identify the specific source of a TZ event when multiple TZ events are enabled to act on a single PWM channel. - InstaSPIN(tm) BLDC LabPDF, 1.4 Мб, Файл опубликован: 15 ноя 2011
For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU (DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo F28035 controlCARD subsystem to run the sensorless InstaSPIN BLDC technique.These are the tasks that must be done to spin motors:Make sure all physical connections and jumper settings on the kit - Custom Bootloader Options via One-Time Programmable (OTP) MemoryPDF, 62 Кб, Файл опубликован: 18 сен 2007
The Boot to One-Time-Programmable (OTP) memory mode in the TMS320x280x devices provides the necessary hooks to support custom bootloaders. This is very useful in a situation where a bootloader option, required by a specific customer application, is not already supported as one of the built-in options in the Boot read-only memory (ROM). This application report includes information and examples on h - Interfacing SD/MMC Cards With TMS320F28xxx DSCsPDF, 1.3 Мб, Файл опубликован: 26 июл 2007
This application report and associated code implements the interfacing of Secure Digital (SD) or Multi-Media Card (MMC) types of Flash memory cards with the TMS320F28xxx digital signal controllers (DSCs). These cards can use serial peripheral interface (SPI) or parallel (SD) interface to connect to the host. This application report demonstrates the SPI mode and includes the schematics showing th - An Easy Way of Creating a C-callable Assembly Function for the TMS320C28x DSPPDF, 185 Кб, Файл опубликован: 30 окт 2001
C-callable assembly routines require an understanding of parameter-passing conventions and environments expected by the C compiler. This application report provides instructions and suggestions to configure the C compiler to assist with these issues. - An Overview of Designing Analog Interface With TM320F28xx/28xxx DSCs (Rev. A)PDF, 655 Кб, Версия: A, Файл опубликован: 14 май 2008
This application report provides guidelines that take you through everything from configuring the ADC and related registers correctly, responding to interrupts, and board design recommendations; this may be particularly useful for first-time users of the TMS320C2000в„ў digital signal processor (DSP) platform devices and for firmware engineers with less exposure to the analog world. Various s - Copying Compiler Sections from Flash to RAM on the TMS320F28xxx DSCs (Rev. A)PDF, 307 Кб, Версия: A, Файл опубликован: 18 авг 2017
This application report and associated code files provide functionality for copying initialized compiler sections from the internal Flash memory to the internal random access memory (RAM) of the TMS320F28xxx digital signal controllers (DSCs) at run time for optimizing execution speed. The solution provided implements this functionality directly after booting before entering the c_int00 C entry rou - Online Stack Overflow Detection on the TMS320C28x DSPPDF, 407 Кб, Файл опубликован: 2 май 2003
A stack overflow in an embedded DSP application generally produces a catastrophic software crash due to data corruption, lost return addresses, or both. Traditional off-line approaches to sizing a stack during development, such as filling with a know value, or estimating based on code content, are not 100% reliable. Therefore, programmers often feel compelled to reserve larger stack sizes than are - Using PWM Output as a Digital-to-Analog Converter on a TMS320F280x (Rev. A)PDF, 381 Кб, Версия: A, Файл опубликован: 9 сен 2008
This application report presents a method for utilizing the on-chip pulse width modulated (PWM) signal generators on the TMS320F280xв„ў family of digital signal controllers as a digital-to-analog converter (DAC). The method involves analog low-pass filtering the PWM signal to remove high frequency components, leaving only the low-frequency content. Theoretical and experimental results are presented - Programming Examples for the TMS320x28xx eCAN (Rev. B)PDF, 73 Кб, Версия: B, Файл опубликован: 12 сен 2017
The TMS320x28xx series of Microcontrollers/Digital Signal Controllers feature an on-chip enhanced Controller Area Network (eCAN) module. This module is a full-CAN controller, compliant with CAN specification 2.0B. This application report contains several programming examples, supplemental to those in C2000Ware/controlSUITE, to illustrate how the eCAN module is set up for different modes of operati - Running an Application from Internal Flash Memory on the TMS320F28xxx DSP (Rev. L)PDF, 641 Кб, Версия: L, Файл опубликован: 28 фев 2013
Several special requirements exist for running an application from on-chip Flash memory on the TMS320F28xxx. These requirements generally do not manifest themselves during code development in RAM since the Code Composer Studioв„ў (CCS) debugger can mask problems associated with initialized sections and their linkage in memory. This application report covers the application software modificatio - Flash Programming Solutions for the TMS320F28xxx DSCsPDF, 423 Кб, Файл опубликован: 19 авг 2008
Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the - Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed. - Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici - Serial Flash Programming of C2000 Microcontrollers (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr - EEPROM Emulation With the TMS320F28xxx DSCsPDF, 407 Кб, Файл опубликован: 21 сен 2009
Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain - Calculator for CAN Bit Timing ParametersPDF, 37 Кб, Файл опубликован: 22 мар 2016
Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat - Programming External Nonvolatile Memory Using SDFlash for TMS320C28x DevicesPDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A - Common Object File Format (COFF)PDF, 125 Кб, Файл опубликован: 15 апр 2009
- TPS75005 Quick-Start Guide with C2000 ControllersPDF, 129 Кб, Файл опубликован: 17 янв 2012
The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller. - PowerPAD Thermally Enhanced Package (Rev. H)PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
Серия: TMS320F28066 (7)
- Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
