Datasheet ATSAM3X8CA-CU - Atmel Даташит Микроконтроллеры (MCU) BGA100, GREEN, IND TEMP, MRLA — Даташит
Наименование модели: ATSAM3X8CA-CU
27 предложений от 16 поставщиков
Микросхема Микроконтроллер, MCU 32Bit SAM3X ARM Cortex M3 RISC 512KB Flash 1.8V/2.5V/3.3V 100Pin LFBGA
ATSAM3X8CA-CU
Atmel
от 264 ₽
ATSAM3X8CA-CU
от 680 ₽
ATSAM3X8CA-CU
Atmel
ATSAM3X8CA-CU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) BGA100, GREEN, IND TEMP, MRLA
data sheetСкачать Data Sheet
Features
· Core
­ ARM® Cortex®-M3 revision 2.0 running at up to 84 MHz ­ Memory Protection Unit (MPU) ­ Thumb®-2 instruction set ­ 24-bit SysTick Counter ­ Nested Vector Interrupt Controller Memories ­ From 256 to 512 Kbytes embedded Flash, 128-bit wide access, memory accelerator, dual bank ­ From 32 to 100 Kbytes embedded SRAM with dual banks ­ 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines ­ Static Memory Controller (SMC): SRAM, NOR, NAND support.
NAND Flash controller with 4-kbyte RAM buffer and ECC System ­ Embedded voltage regulator for single supply operation ­ POR, BOD and Watchdog for safe reset ­ Quartz or ceramic resonator oscillators: 3 to 20 MHz main and optional low power 32.768 kHz for RTC or device clock. ­ High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz Default Frequency for fast device startup ­ Slow Clock Internal RC oscillator as permanent clock for device clock in low power mode ­ One PLL for device clock and o
  • Шина данных: 32 бит
  • RoHS: да
ATSAM3X8CACU, ATSAM3X8CA CU
На английском языке: Datasheet ATSAM3X8CA-CU - Atmel Microcontrollers (MCU) BGA100, GREEN, IND TEMP, MRLA
