Datasheet Texas Instruments MSP430G2553IPW28R — Даташит
СерияMSP430G2553
МодельMSP430G2553IPW28R
MSP430G2x53, MSP430G2x13 Микроконтроллер смешанных сигналов 28-TSSOP от -40 до 85
MSP430G2x53, MSP430G2x13 Mixed Signal Microcontroller datasheet
PDF, 1.5 Мб, Версия: J, Файл опубликован: 16 май 2013
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка430G2553
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
ADCADC10 - 8ch
AESN/A
Active Power330 uA/MHz
Additional FeaturesWatchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
Comparators8
Featuredg2
Тактовая частота16 МГц
GPIO Pins24
I2C1
Max VCC3.6
Min VCC1.8
MultiplierN/A
Non-volatile Memory16 KB
Package GroupTSSOP
RAM0.5 KB
SPI2
Special I/OCapacitive Touch I/O
Standby Power0.7 LPM3-uA
Timers - 16-bit2
UART1
Wakeup Time1.5 us
  • Evaluation Modules & Boards: 430BOOST-CC110L
    CC110L RF BoosterPack
  • Evaluation Modules & Boards: 430BOOST-SENSE1
    MSP430 Capacitive Touch BoosterPack
  • Evaluation Modules & Boards: DRV8850EVM
    DRV8850EVM - Evaluation Module for Low-Voltage H-Bridge Motor Driver with LDO Voltage Regulator
  • Evaluation Modules & Boards: 430BOOST-ADS1118
    ADS1118 BoosterPack
  • Evaluation Modules & Boards: DRV8701EVM
    DRV8701 Full Bridge Brushed DC Motor Gate Driver Evaluation Module
  • Evaluation Modules & Boards: DLP-7970ABP
    NFC Transceiver Booster Pack
  • Evaluation Modules & Boards: DRV8308EVM
    DRV8308EVM Evaluation Module for Three-phase Brushless Motor Pre-driver
  • Daughter Cards: BOOST-IR
    Infrared (IR) BoosterPack Plug-in Module
  • Evaluation Modules & Boards: DRV8703-Q1EVM
    DRV8703-Q1 Automotive Brushed DC Gate Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8702D-Q1EVM
    DRV8702D-Q1 Automotive Half-Bridge Brushed DC Motor Gate Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8702-Q1EVM
    DRV8702-Q1 Automotive Brushed DC Motor Gate Driver Evaluation Module
  • Evaluation Modules & Boards: DRV8703D-Q1EVM
    DRV8703D-Q1 Automotive Half-Bridge Brushed DC Motor Gate Driver With SPI Evaluation Module
  • Evaluation Modules & Boards: 430BOOST-SHARP96
    Sharp В® Memory LCD BoosterPack
  • Evaluation Modules & Boards: DRV8313EVM
    DRV8313 Evaluation Module
  • Evaluation Modules & Boards: MSP-TS430PW28A
    MSP-TS430PW28A - 28-pin Target Development Board for MSP430F2x and MSP430G2x MCUs
  • Evaluation Modules & Boards: MSP-EXP430G2
    MSP430 LaunchPad Value Line Development kit
  • Development Kits: MSP-FET430U28A
    28-pin Target Development Board and MSP-FET USB Programmer Bundle for MSP430F2x and MSP430G2x MCUs
    MSP EnergyTrace Technology
  • Utilizing the DRV10 Frequency Generator for Closed Loop Speed Control
    PDF, 152 Кб, Файл опубликован: 19 дек 2012
  • Automating Audio Bluetooth Connectivity Using NFC Secure Simple Pairing
    PDF, 610 Кб, Файл опубликован: 25 мар 2013
    The NFC Forum and the BluetoothВ® Special Interest Group (SIG) collaborated to produce an application document entitled, NFC Forum Bluetooth Secure Simple Pairing Using NFC Application Document located at NFCForum-AD-BTSSP_1.0. This collaborative document is a follow up to a previously released specification by the NFC Forum entitled, NFC Forum Connection Handover Specification, which began t
  • TIC Digital Interface (Rev. A)
    PDF, 976 Кб, Версия: A, Файл опубликован: 2 дек 2013
  • CC112x-CC1190 Boost Software Examples
    PDF, 55 Кб, Файл опубликован: 19 окт 2015
  • Software Glass LCD Driver Based on MSP430 MCU (Rev. A)
    PDF, 359 Кб, Версия: A, Файл опубликован: 6 авг 2012
  • Capacitive Touch Sensing, MSP430 Button Gate Time Optimization and Tuning Guide
    PDF, 1.1 Мб, Файл опубликован: 21 май 2013
    MSP430в„ў microcontroller based capacitive touch buttons can offer increased performance when properly optimized and tuned for their specific application. Performance benefits that result from button optimization can include, but are not limited to, decreased power consumption, improved response time, and the ability to grow a design to include more buttons. This application report provides th
  • Capacitive Touch Sensing, MSP430 Slider and Wheel Tuning Guide
    PDF, 1.0 Мб, Файл опубликован: 21 май 2013
    This application report provides guidelines on how to tune capacitive touch sliders and wheels running on the MSP430в„ў microcontrollers. It identifies the hardware and software parameters as well as explains the steps used in tuning sliders and wheels.The slider and wheel tuning is based on the APIs defined within the Capacitive Touch Sense Library (CAPSENSELIBRARY).
  • Capacitive Touch Hardware Design Guide (Rev. A)
    PDF, 784 Кб, Версия: A, Файл опубликован: 17 ноя 2015
    Capacitive touch detection is sometimes considered more art than science. This often results in multiple design iterations before the optimum performance is achieved. There are, however, good design practices for circuit layout and principles of materials that need to be understood to keep the number of iterations to a minimum. This design guide describes a process for creating and designing capac
  • 1-uA Capacitive Grip Detection Based on MSP430 Microcontrollers (Rev. B)
    PDF, 373 Кб, Версия: B, Файл опубликован: 14 авг 2013
    This application report discusses how to design a simple and ultra low-power grip detector BoosterPack for the MSP430 LaunchPadв„ў. The PINOSC feature in every msp430G2xx2 and msp430G2xx3 device makes it possible to eliminate all the external components when implementing a capacitive touch design. All the components used in the grip detector, such as capacitive sensors, LEDs are all integrate
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • Migrating from the MSP430F2xx,G2xx Family to the MSP430FR58xx/FR59xx/68xx/69xx (Rev. E)
    PDF, 179 Кб, Версия: E, Файл опубликован: 3 ноя 2016
    This application report enables easy migration from MSP430F2xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx family of FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two f
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430G2x/i2x
На английском языке: Datasheet Texas Instruments MSP430G2553IPW28R
