Datasheet Texas Instruments MSP430F6720IPN — Даташит
| Серия | MSP430F6720 |
| Модель | MSP430F6720IPN |
MSP430F673x, MSP430F672x Микроконтроллер смешанных сигналов 80-LQFP от -40 до 85
MSP430F673x, MSP430F672x Mixed Signal Microcontroller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 27 фев 2013
|  Купить MSP430F6720IPN на РадиоЛоцман.Цены — от 143 до 1 306 ₽ 36 предложений от 15 поставщиков IC MCU 16BIT 16KB FLASH 80LQFP. CPUXV2 MSP430F6xx Microcontroller IC 16-Bit 25MHz 16KB (16K x 8) FLASH 80-LQFP (12x12). Embedded -... | |||
| MSP430F6720IPN Texas Instruments | 236 ₽ | ||
| MSP430F6720IPN Texas Instruments | 544 ₽ | ||
| MSP430F6720IPN Texas Instruments | 600 ₽ | ||
| MSP430F6720IPN Texas Instruments | 1 306 ₽ | ||
| Pin | 80 |
| Package Type | PN |
| Industry STD Term | LQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 119 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | F6720 |
| Width (мм) | 12 |
| Length (мм) | 12 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
| ADC | ADC10 - 6ch,SigmaDelta24 - 2ch |
| AES | N/A |
| Active Power | 346 uA/MHz |
| Additional Features | LCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA |
| BSL | UART |
| CPU | MSP430 |
| DMA | 3 |
| Featured | f6 |
| Тактовая частота | 25 МГц |
| GPIO Pins | 72 |
| I2C | 1 |
| Max VCC | 3.6 |
| Min VCC | 1.8 |
| Multiplier | 32x32 |
| Non-volatile Memory | 16 KB |
| Package Group | LQFP |
| Package Size: mm2:W x L | 80LQFP: 196 mm2: 14 x 14(LQFP) PKG |
| RAM | 1 KB |
| Rating | Catalog |
| SPI | 4 |
| Special I/O | N/A |
| Standby Power | 2.9 LPM3-uA |
| Timers - 16-bit | 4 |
| UART | 3 |
| Wakeup Time | 3 us |
- Evaluation Modules & Boards: MSP-FET430U100B
 100-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F6x MCUs
- Evaluation Modules & Boards: MSP-TS430PZ100B
 MSP-TS430PZ100B - 100-pin Target Development Board for MSP430F6x MCUs
- Evaluation Modules & Boards: EVM430-F6736
 EVM430-F6736 - MSP430F6736 EVM for Metering
- JTAG Emulators/ Analyzers: ENERGYTRACE
 MSP EnergyTrace Technology
- Using TI’s DLMS COSEM LibraryPDF, 74 Кб, Файл опубликован: 12 ноя 2013
 This application report describes in detail the usage of DLMS COSEM library developed by Texas Instruments for customers who use TI's microcontrollers in metering applications. The library is provided as object coded with a configuration file for ease of use. The library can be obtained by contacting the regional sales and marketing offices. The customer will have to sign an SLA before getting acc
- Designing With MSP430 and Segment LCDs (Rev. A)PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
 Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
- Migrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
 This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between the
- General Oversampling of MSP ADCs for Higher Resolution (Rev. A)PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
 Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
- MSP Code Protection FeaturesPDF, 752 Кб, Файл опубликован: 7 дек 2015
 MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
- Design Considerations When Using the MSP430 Graphics LibraryPDF, 475 Кб, Файл опубликован: 5 окт 2012
 LCDs are a growing commodity in todays market with products as diverse as children's toys to medical devices. Modern LCDs, along with the graphics displayed on them, are growing in complexity. A graphics library can simplify and accelerate development while creating the desired user experience. TI provides the MSP430 Graphics Library for use in developing products with the MSP430в„ў MCU. This
- ESD Diode Current SpecificationPDF, 520 Кб, Файл опубликован: 7 дек 2015
 This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
Серия: MSP430F6720 (4)
- MSP430F6720IPN MSP430F6720IPNR MSP430F6720IPZ MSP430F6720IPZR
- Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
