Datasheet LPC1776FBD208,551 - NXP Даташит Микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 80 Кб SRAM USB 2.0 — Даташит
Наименование модели: LPC1776FBD208,551
![]() 22 предложений от 16 поставщиков Микросхема Микроконтроллер, NXP LPC1776FBD208,551 32Bit Microcontroller, ARM Cortex-M3, 120MHz, 256KB, 80KB, 208Pins, LQFP | |||
LPC1776FBD208,551 NXP | 80 ₽ | ||
LPC1776FBD208,551 Nexperia | 1 781 ₽ | ||
LPC1776FBD208,551 NXP | по запросу | ||
Производитель: NXP
Описание: Микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 80 Кб SRAM USB 2.0
LPC178x/7x
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 96 kB SRAM; USB Device/Host/OTG; Ethernet; LCD; EMC
Rev.
3 -- 27 December 2011 Objective data sheet
1. General description
The LPC178x/7x is an ARM Cortex-M3 based microcontroller for embedded applications requiring a high level of integration and low power dissipation. The Cortex-M3 is a next generation core that offers better performance than the ARM7 at the same clock rate and other system enhancements such as modernized debug features and a higher level of support block integration. The Cortex-M3 CPU incorporates a 3-stage pipeline and has a Harvard architecture with separate local instruction and data buses, as well as a third bus with slightly lower performance for peripherals. The Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branches. The LPC178x/7x adds a specialized flash memory accelerator to accomplish optimal performance when executing code from flash. The LPC178x/7x
- Упаковка: Tray
- RoHS: да
LPC1776FBD208551, LPC1776FBD208 551
