Линейка продуктов KEEN SIDE
Datasheet Texas Instruments MSP430F6733IPN — Даташит
СерияMSP430F6733
МодельMSP430F6733IPN
MSP430F673x, MSP430F672x Микроконтроллер смешанных сигналов 80-LQFP от -40 до 85
MSP430F673x, MSP430F672x Mixed Signal Microcontroller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 27 фев 2013
Pin80
Package TypePN
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY119
МаркировкаF6733
Width (мм)12
Length (мм)12
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC10 - 6ch,SigmaDelta24 - 3ch
AESN/A
Active Power346 uA/MHz
Additional FeaturesLCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
DMA3
Featuredf6
Тактовая частота25 МГц
GPIO Pins72
I2C1
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory64 KB
Package GroupLQFP
Package Size: mm2:W x L80LQFP: 196 mm2: 14 x 14(LQFP) PKG
RAM4 KB
SPI4
Special I/ON/A
Standby Power2.9 LPM3-uA
Timers - 16-bit4
UART3
Wakeup Time3 us
  • Evaluation Modules & Boards: MSP-FET430U100B
    100-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F6x MCUs
  • Evaluation Modules & Boards: MSP-TS430PZ100B
    MSP-TS430PZ100B - 100-pin Target Development Board for MSP430F6x MCUs
  • Evaluation Modules & Boards: EVM430-F6736
    EVM430-F6736 - MSP430F6736 EVM for Metering
    MSP EnergyTrace Technology
  • Using TI’s DLMS COSEM Library
    PDF, 74 Кб, Файл опубликован: 12 ноя 2013
    This application report describes in detail the usage of DLMS COSEM library developed by Texas Instruments for customers who use TI's microcontrollers in metering applications. The library is provided as object coded with a configuration file for ease of use. The library can be obtained by contacting the regional sales and marketing offices. The customer will have to sign an SLA before getting acc
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • Migrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)
    PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
    This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between the
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • MSP Code Protection Features
    PDF, 752 Кб, Файл опубликован: 7 дек 2015
    MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
  • Design Considerations When Using the MSP430 Graphics Library
    PDF, 475 Кб, Файл опубликован: 5 окт 2012
    LCDs are a growing commodity in todays market with products as diverse as children's toys to medical devices. Modern LCDs, along with the graphics displayed on them, are growing in complexity. A graphics library can simplify and accelerate development while creating the desired user experience. TI provides the MSP430 Graphics Library for use in developing products with the MSP430в„ў MCU. This
  • ESD Diode Current Specification
    PDF, 520 Кб, Файл опубликован: 7 дек 2015
    This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430F6733IPN
