Datasheet Microchip DSPIC33FJ06GS202A-I/SP — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ06GS202A |
| Модель | DSPIC33FJ06GS202A-I/SP |
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ06GS001/101A/102A/202A and dsPIC33FJ09GS302 Data Sheet
PDF, 3.4 Мб, Версия: 08-21-2012
Купить DSPIC33FJ06GS202A-I/SP на РадиоЛоцман.Цены — от 164 до 692 ₽25 предложений от 17 поставщиков IC MCU 16BIT 6KB FLASH 28SDIP. dsPIC dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 6KB (2K x 24) FLASH 28-SPDIP.... | |||
| DSPIC33FJ06GS202A-I/SP Microchip | 164 ₽ | ||
| DSPIC33FJ06GS202A-I/SP Microchip | 267 ₽ | ||
| DSPIC33FJ06GS202A-I/SP Microchip | по запросу | ||
| Корпус | SPDIP |
| Количество выводов | 28 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| Cap. Touch Channels | 6 |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 5 including complementary outputs |
| Max 16 Bit Digital Timers | 2 |
| Max A/D Resolution | 10 bits |
| Max D/A Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Number of D/A Converters | 2 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 6 Kbytes |
| RAM | 1024 bytes |
| SPIв„ў | 1 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 6 |
| UART | 1 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
dsPIC33FJ06GS001 dsPIC33FJ06GS101A dsPIC33FJ06GS102A dsPIC33FJ09GS302
Серия: dsPIC33FJ06GS202A (10)
DSPIC33FJ06GS202AI/SP, DSPIC33FJ06GS202A I/SP
