Datasheet STPS80H100TV - STMicroelectronics Даташит Шоттки выпрямитель, сдвоенный 40 А ISOTOP — Даташит
STMicroelectronics STPS80H100TV
Наименование модели: STPS80H100TV
Описание: Шоттки выпрямитель, сдвоенный 40 А ISOTOP
data sheetСкачать Data Sheet
STPS80H100TV
HIGH VOLTAGE POWER SCHOTTKY RECTIFIER
MAIN PRODUCT CHARACTERISTICS IF(AV) VRRM Tj (max) VF (max) FEATURES AND BENEFITS NEGLIGIBLE SWITCHING LOSSES HIGH JUNCTION TEMPERATURE CAPABILITY LOW LEAKAGE CURRENT GOOD TRADE OFF BETWEEN LEAKAGE CURRENT AND FORWARD VOLTAGE DROP AVALANCHE RATED LOW INDUCTANCE PACKAGE INSULATED PACKAGE : Insulated voltage = 2500 V(RMS) Capacitance = 45 pF DESCRIPTION High voltage dual Schottky barrier rectifier designed for high frequency telecom and computer Switched Mode Power Supplies and other power converters.
ABSOLUTE RATINGS (limiting values, per diode) Symbol VRRM IF(RMS) IF(AV) IFSM IRRM IRSM Tstg Tj dV/dt RMS forward current Average forward current Surge non repetitive forward current Repetitive peak reverse current Non repetitive peak reverse current Storage temperature range Maximum operating junction temperature * Critical rate of rise of reverse voltage Tc = 120°C = 0.5 tp = 10 ms sinusoidal tp = 2 µs square F = 1kHz tp = 100 µs squa
  • Diode Configuration: Dual Independent
  • Diode Type: Schottky
  • Forward Current If(AV): 40 А
  • Forward Surge Current Ifsm Max: 700 А
  • Forward Voltage VF Max: 650 мВ
  • Repetitive Reverse Voltage Vrrm Max: 100 В
  • RoHS: да
На английском языке: Datasheet STPS80H100TV - STMicroelectronics SCHOTTKY RECTIFIER, DUAL 40 A ISOTOP
Политика конфиденциальности
