Datasheet LPC2220FET144/G,55 - NXP Даташит ARM микроконтроллеры (MCU) ARM7 64KR/ADC/EX BUS ROMLESS — Даташит
Наименование модели: LPC2220FET144/G,55
|  Купить LPC2220FET144/G,55 на РадиоЛоцман.Цены — от 287 до 1 740 ₽ 16 предложений от 15 поставщиков Микросхема Микроконтроллер, LPC2210/2220 - 16/32Bit ARM microcontrollers; flashless, with 10Bit ADC and external memory interface BGA 144Pin | |||
| LPC2220FET144/G,55 NXP | 287 ₽ | ||
| LPC2220FET144/G,55 | 447 ₽ | ||
| LPC2220FET144/G,55 NXP | 682 ₽ | ||
| LPC2220FET144/G,55 NXP | 1 740 ₽ | ||
Производитель: NXP
Описание: ARM микроконтроллеры (MCU) ARM7 64KR/ADC/EX BUS ROMLESS
LPC2210/2220
16/32-bit ARM microcontrollers; flashless, with 10-bit ADC and external memory interface
Rev.
06 -- 11 December 2008 Product data sheet
1. General description
The LPC2210/2220 microcontrollers are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation and embedded trace support. For critical code size applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with minimal performance penalty. With their 144-pin package, low power consumption, various 32-bit timers, 8-channel 10-bit ADC, PWM channels, and up to nine external interrupt pins these microcontrollers are particularly suitable for industrial control, medical systems, access control and point-of-sale. The LPC2210/2220 can provide up to 76 GPIOs depending on bus configuration. With a wide range of serial communications interfaces, it is also very well suited for communication gateways, protocol converters and embedded soft modems as well as many other general-purpose applications. Remark:
- Supply Voltage - Max: 1.95 В, 3.6 В
- Supply Voltage - Min: 1.65 В, 2.5 В, 3 В
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Высота: 0.8 мм
- Длина: 12 мм
- Интерфейс: I2C, SPI, SSP, UART
- Количество линий ввода/вывода: 76
- Количество таймеров: 2
- Рабочее напряжение питания: 1.65 В ... 1.95 В, 3 В ... 3.6 В
- Размер ОЗУ: 64 Кб
- Серия процессора: LPC22
- Тактовая частота максимальная: 75 МГц
- Тип корпуса: SOT-569
- Тип памяти программ: ROMLess
- Упаковка: Tray
- Шина данных: 16 bit/32 бит
- Ширина: 12 мм
- Ядро: ARM7TDMI-S
- RoHS: да
- Другие названия товара: LPC2220FET144/G-S
LPC2220FET144/G55, LPC2220FET144/G 55
 Скачать Data Sheet
Скачать Data Sheet
