Datasheet LPC2119FBD64/01,15 - NXP Даташит ARM микроконтроллеры (MCU) ARM7/128K FL/CAN/ADC — Даташит
Наименование модели: LPC2119FBD64/01,15
|  Купить LPC2119FBD64/01,15 на РадиоЛоцман.Цены — от 391 до 1 169 ₽ 15 предложений от 15 поставщиков Микросхема Микроконтроллер, LPC2109/2119/2129 - Single-chip 16/32Bit microcontrollers; 64/128/256KB ISP/IAP flash with 10Bit ADC and CAN QFP 64Pin | |||
| LPC2119FBD64/01,15 NXP | 391 ₽ | ||
| LPC2119FBD64/01,15 Rochester Electronics | 804 ₽ | ||
| LPC2119FBD64/0115 NXP | 807 ₽ | ||
| LPC2119FBD64/01,15 NXP | по запросу | ||
Производитель: NXP
Описание: ARM микроконтроллеры (MCU) ARM7/128K FL/CAN/ADC
LPC2109/2119/2129
Single-chip 16/32-bit microcontrollers; 64/128/256 kB ISP/IAP flash with 10-bit ADC and CAN
Rev.
7 -- 14 June 2011 Product data sheet
1. General description
The LPC2109/2119/2129 are based on a 16/32-bit ARM7TDMI-S CPU with real-time emulation and embedded trace support, together with 64/128/256 kB of embedded high-speed flash memory. A 128-bit wide memory interface and a unique accelerator architecture enable 32-bit code execution at maximum clock rate. For critical code size applications, the alternative 16-bit Thumb mode reduces code by more than 30 % with minimal performance penalty. With their compact 64-pin package, low power consumption, various 32-bit timers, 4-channel 10-bit ADC, two advanced CAN channels, PWM channels and 46 fast GPIO lines with up to nine external interrupt pins these microcontrollers are particularly suitable for automotive and industrial control applications, as well as medical systems and fault-tolerant maintenance buses. With a wide ra
- On-Chip DAC: нет
- Supply Voltage - Max: 1.95 В, 3.6 В
- Supply Voltage - Min: 1.65 В, 2.5 В, 3 В
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Высота: 1.45 мм
- Длина: 10.1 мм
- Доступные аналоговые/цифровые каналы: 4
- Интерфейс: CAN, I2C, JTAG, SPI, SSP, UART
- Количество линий ввода/вывода: 46
- Количество таймеров: 2
- Рабочее напряжение питания: 3.3 В
- Размер ОЗУ: 16 Кб
- Размер памяти программ: 128 Кб
- Разрядность АЦП: 10 бит
- Серия процессора: LPC21
- Тактовая частота максимальная: 30 МГц
- Тип корпуса: SOT-314-2
- Тип памяти программ: Flash
- Упаковка: Tray
- Шина данных: 16 bit/32 бит
- Ширина: 10.1 мм
- Ядро: ARM7TDMI-S
- RoHS: да
- Другие названия товара: LPC2119FBD64/01-S
LPC2119FBD64/0115, LPC2119FBD64/01 15
 Скачать Data Sheet
Скачать Data Sheet
