Datasheet ATMEGA256RZBV-8CU - Atmel Даташит ВЧ микроконтроллеры (MCU) AVR Z-Link BUNDLE — Даташит
Atmel ATMEGA256RZBV-8CU
Наименование модели: ATMEGA256RZBV-8CU
Микросхема Микроконтроллер 8, ATMEL ATMEGA256RZBV-8CU MCU-Application Specific 8Bit, MEGAAVR, 16MHz, 8KB RAM/256KB Program, 1.8V-5.5Vin, PBGA-100
ATMEGA256RZBV-8CU
Atmel
370 ₽
ATMEGA256RZBV-8CU
Atmel
1 018 ₽
ATMEGA256RZBV-8CU
2 169 ₽
ATMEGA256RZBV-8CU
Производитель: Atmel
Описание: ВЧ микроконтроллеры (MCU) AVR Z-Link BUNDLE
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel® AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 135 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 32 Ч 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 16 MIPS Throughput at 16 MHz ­ On-Chip 2-cycle Multiplier High Endurance Non-volatile Memory Segments ­ 64K/128K/256K Bytes of In-System Self-Programmable Flash ­ 4 Kbytes EEPROM ­ 8 Kbytes Internal SRAM ­ Write/Erase Cycles:10,000 Flash/100,000 EEPROM ­ Data retention: 20 years at 85°C/ 100 years at 25°C ­ Optional Boot Code Section with Independent Lock Bits · In-System Programming by On-chip Boot Program · True Read-While-Write Operation ­ Programming Lock for Software Security · Endurance: Up to 64 Kbytes Optional External Memory Space JTAG (IEEE std.
1149.1 compliant) Interface ­ Boundary-scan Capabilities According to the JTAG Standard ­ Extensive On-chip Debug Support ­ Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Inte
  • Интерфейс: SPI, USART
  • RoHS: да
ATMEGA256RZBV8CU, ATMEGA256RZBV 8CU
На английском языке: Datasheet ATMEGA256RZBV-8CU - Atmel RF Microcontrollers (MCU) AVR Z-Link BUNDLE
