Datasheet Texas Instruments TPA2011D1YFFT — Даташит
Серия | TPA2011D1 |
Модель | TPA2011D1YFFT |
Моно 3,2 Вт класса d с автоматическим восстановлением защиты от короткого замыкания 9-DSBGA от -40 до 85
TPA2011D1 3.2-W Mono Filter-Free Class-D Audio Power Amplifier With Auto-Recovering Short-Circuit Protection datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 4 ноя 2015
Pin | 9 |
Package Type | YFF |
Industry STD Term | DSBGA |
JEDEC Code | S-XBGA-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | OEW |
Width (мм) | 1.4 |
Length (мм) | 1.4 |
Thickness (мм) | .425 |
Pitch (мм) | .4 |
Max Height (мм) | .625 |
Mechanical Data | Скачать |
Analog Supply (V) | 1.8 Max |
Архитектура | Class D |
Audio Input Type | Analog Input |
Control Interface | Hardware |
Iq per channel(Typ) | 1.8 мА |
Iq(Max) | 2.5 мА |
Iq(Typ) | 1.8 мА |
Load(Min) | 4 ohms |
Выходная мощность | 3.2 W |
PSRR | 86 дБ |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Pin/Package | 9DSBGA |
Rating | Catalog |
Shutdown Current (ISD) | 0.1 uA |
Speaker Channels | Mono Max |
THD + N @ 1 kHz | 0.23 % |
- Evaluation Modules & Boards: TPA2011D1YFFEVM
TPA2011D1YFF Evaluation Module
- AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2011D1 (4)
- HPA01086YFFR HPA01203YFFR TPA2011D1YFFR TPA2011D1YFFT
- Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
