Datasheet LTC6362HDD - Linear Technology Даташит DIFF, усилитель, драйвер, ADC, 180 МГц, 8DFN — Даташит
Наименование модели: LTC6362HDD
![]() 30 предложений от 13 поставщиков IC OPAMP DIFF 1 CIRCUIT 8DFN / Differential Amplifier 1 Circuit Differential, Rail-to-Rail 8-DFN (3x3) | |||
LTC6362HDD#PBF Linear Technology | от 80 ₽ | ||
LTC6362HDD#TRPBF Analog Devices | 88 ₽ | ||
LTC6362HDD Analog Devices | от 176 ₽ | ||
LTC6362HDD#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: DIFF, усилитель, драйвер, ADC, 180 МГц, 8DFN
FEATURES
n n n n n n n n n n n n n
LTC6362 Precision, Low Power Rail-to-Rail Input/Output Differential Op Amp/SAR ADC Driver DESCRIPTION
The LTC®6362 is a low power, low noise differential op amp with rail-to-rail input and output swing that has been optimized to drive low power SAR ADCs.
The LTC6362 draws only 1mA of supply current in active operation, and features a shutdown mode in which the current consumption is reduced to 70A. The amplifier may be configured to convert a singleended input signal to a differential output signal, and is capable of being operated in an inverting or noninverting configuration. Low offset voltage, low input bias current, and a stable high impedance configuration make this amplifier suitable for use not only as an ADC driver but also earlier in the signal chain, to convert a precision sensor signal to a balanced (differential) signal for processing in noisy industrial environments. The LTC6362 is available in an 8-lead MSOP package and also in a compa
- Диапазон напряжения питания: 2.8 В ... 5.25 В
- Количество выводов: 8
- Количество усилителей: 1
- Напряжение смещения входа: 50 мкВ
- Полоса частот: 180 МГц
- Рабочий диапазон температрур: -40°C ... +125°C
- Скорость нарастания: 45 В/мкс
- Тип корпуса: DFN
- Ток потребления: 1 мА
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
