Datasheet LPC1317FBD64,551 - NXP Даташит ARM микроконтроллеры (MCU) 32 бит ARM Cortex-M3 64 Кб Flash 10 Кб SRAM — Даташит
Наименование модели: LPC1317FBD64,551
![]() 34 предложений от 14 поставщиков Микросхема Микроконтроллер, MCU 32Bit LPC1300 ARM Cortex M3 RISC 64KB Flash 2.5V/3.3V 64Pin LQFP Tray | |||
LPC1317FBD64,551 NXP | от 119 ₽ | ||
LPC1317FBD64,551 NXP | от 393 ₽ | ||
LPC1317FBD64,551 NXP | 416 ₽ | ||
LPC1317FBD64,551 NXP | от 751 ₽ |
Производитель: NXP
Описание: ARM микроконтроллеры (MCU) 32 бит ARM Cortex-M3 64 Кб Flash 10 Кб SRAM
LPC1315/16/17/45/46/47
32-bit ARM Cortex-M3 microcontroller; up to 64 kB flash; up to 12 kB SRAM; USB device; USART; EEPROM
Rev.
2 -- 18 July 2012 Product data sheet
1. General description
The LPC1315/16/17/45/46/47 are ARM Cortex-M3 based microcontrollers for embedded applications featuring a high level of integration and low power consumption. The ARM Cortex-M3 is a next generation core that offers system enhancements such as enhanced debug features and a higher level of support block integration. The LPC1315/16/17/45/46/47 operate at CPU frequencies of up to 72 MHz. The ARM Cortex-M3 CPU incorporates a 3-stage pipeline and uses a Harvard architecture with separate local instruction and data buses as well as a third bus for peripherals. The ARM Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branching. Equipped with a highly flexible and configurable Full-Speed USB 2.0 device controller available on the LPC1345/46/47, this series brings unparalleled d
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Рабочее напряжение питания: 2 В ... 3.6 В
- Размер ОЗУ: 8 Кб
- Размер памяти программ: 64 Кб
- Серия процессора: LPC1317
- Тактовая частота максимальная: 72 МГц
- Тип корпуса: LQFP-64
- Упаковка: Tray
- Шина данных: 32 бит
- Ядро: ARM Cortex M3
- RoHS: да
LPC1317FBD64551, LPC1317FBD64 551
