Datasheet LPC4357FET256,551 - NXP Даташит ARM микроконтроллеры (MCU) 1 Мб Flash 136 Кб SRAM Cortex-M4/M0 — Даташит
Наименование модели: LPC4357FET256,551
![]() 16 предложений от 13 поставщиков IC MCU 32BIT 1MB FLASH 256LBGA. ARM® Cortex®-M4/M0 LPC43xx Microcontroller IC 32-Bit Dual-Core 204MHz 1MB (1M x 8) FLASH 256-LBGA (17x17).... | |||
LPC4357FET256,551 NXP | от 14 ₽ | ||
LPC4357FET256,551 NXP | 37 ₽ | ||
LPC4357FET256,551 | 620 ₽ | ||
LPC4357FET256,551 NXP | по запросу |
Производитель: NXP
Описание: ARM микроконтроллеры (MCU) 1 Мб Flash 136 Кб SRAM Cortex-M4/M0
LPC4357/53/37/33
32-bit ARM Cortex-M4/M0 MCU; up to 1 MB flash and 136 kB SRAM; Ethernet, two High-speed USB, LCD, EMC
Rev.
2 -- 11 July 2012 Preliminary data sheet
1. General description
The LPC4357/53/37/33 are ARM Cortex-M4 based microcontrollers for embedded applications which include an ARM Cortex-M0 coprocessor, up to 1 MB of flash and 136 kB of on-chip SRAM, 16 kB of EEPROM memory, advanced configurable peripherals such as the State Configurable Timer (SCT) and the Serial General Purpose I/O (SGPIO) interface, two High-speed USB controllers, Ethernet, LCD, an external memory controller, and multiple digital and analog peripherals. The LPC4357/53/37/33 operate at CPU frequencies of up to 204 MHz. The ARM Cortex-M4 is a next generation 32-bit core that offers system enhancements such as low power consumption, enhanced debug features, and a high level of support block integration. The ARM Cortex-M4 CPU incorporates a 3-stage pipeline, uses a Harvard architecture with separate loca
- Вид монтажа: SMD/SMT
- Встроенный в чип АЦП: да
- Рабочее напряжение питания: 2.2 В ... 3.6 В
- Размер ОЗУ: 136 Кб
- Размер памяти программ: 1 Мб
- Серия процессора: LPC4357
- Тактовая частота максимальная: 400 кГц
- Тип корпуса: LBGA-256
- Упаковка: Tray
- Шина данных: 32 бит
- Ядро: ARM Cortex M4/M0
- RoHS: да
LPC4357FET256551, LPC4357FET256 551
