Оптопары и оптореле Megawin
Datasheet Texas Instruments CC430F5125IRGZT — Даташит
СерияCC430F5125
МодельCC430F5125IRGZT
CC430F614x, CC430F514x, CC430F512x SoC с RF Core 48-VQFN от -40 до 85
CC430F614x, CC430F514x, CC430F512x SoC With RF Core datasheet
PDF, 1.7 Мб, Версия: A, Файл опубликован: 27 фев 2013
Pin4848
Package TypeRGZRGZ
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаF5125CC430
Width (мм)77
Length (мм)77
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
ADCSlope
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset
Antenna ConnectionDifferential
CPUMSP430
CPU CoreMSP430
CPU Processing Power Consumption160 uA/MHz
Data Rate (Max)500 kbps
Flash16 KB
Тактовая частота20 МГц
Frequency Bands315,433,779,868,915,920 МГц
GPIO30
I2C1
Key ApplicationsData logging, Remote monitoring systems, Wireless sensor networks
Max VCC3.6
Min VCC1.8
Non-volatile Memory16 KB
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
RAM2 KB
RF standard supportedProprietary (Sub 1GHz)
ROMN/A KB
RX Current (Lowest)15 мА
SPI1
SRAM2 kB
SecurityAES
Standard versionN/A
Standby Current2 uA
Timers - 16-bit2
UART1
Wake-on radioYes
Wakeup time from standby240 us
  • Evaluation Modules & Boards: MSP-SA430-SUB1GHZ
    Sub-1 GHz RF Spectrum Analyzer Tool
  • CC430 Wake-On-Radio Functionality (Rev. A)
    PDF, 210 Кб, Версия: A, Файл опубликован: 10 июл 2012
    The Wake-On-Radio (WOR) feature of the CC430 is a recommended method for conserving power in wireless systems in which the radio periodically wakes up from SLEEP mode and listens for incoming packets. This application note describes the theory, RF1A registers, and timing of the WOR feature. It also describes the special use case of the CC430F61xx and CC430F51xx devices. This application note concl
  • CC430 RF Examples (Rev. C)
    PDF, 117 Кб, Версия: C, Файл опубликован: 7 сен 2012
    This application report describes the library components and implementation of the RF code examples for the CC430F61xx and CC430F51xx sub-1GHz system-on-chip (SoC) devices. The examples include support for packet-handling modes, including variable and fixed length filtering, as well as the asynchronous and synchronous modes of communication. The document also explains the key RF configuration regi
  • CC430-Based Wireless Mesh Network Mains Switch
    PDF, 966 Кб, Файл опубликован: 20 май 2011
    This application report describes a simple wireless mesh network running on a number of wireless power points. Each power point contains a timer switch and a power monitor. The mesh network is self learning. A data concentrator works through the various power points it discovers and forms a network. It can then program the on/off timing of the power point's switch and monitor its power consumption
  • AN088 -- SimpliciTI on the CC430 – Practical Modifications
    PDF, 89 Кб, Файл опубликован: 10 мар 2010
  • Using a DC-DC Converter to Reduce Power (Current) Consumption In CC430 Systems
    PDF, 4.6 Мб, Файл опубликован: 5 июл 2011
    This application report describes a method to reduce power consumption in CC430-based systems by using a step-down converter TPS62730.
  • AN072 -- Using the TAI-SAW TA0801A SAW Filter and External PA (Rev. A)
    PDF, 359 Кб, Версия: A, Файл опубликован: 19 авг 2009
  • AN050 -- Using the CC1101 in the European 868MHz SRD band (Rev. B)
    PDF, 223 Кб, Версия: B, Файл опубликован: 11 сен 2009
  • DN508 -- Frequency Scanning using CC430Fx, CC110x, and CC111xFx
    PDF, 65 Кб, Файл опубликован: 25 янв 2010
    The purpose of this design note is to show the necessary steps to successfully scan through a frequency band covering n numbers of channels, and find the strongest signal in the band.
  • DN022 -- CC110x CC111x OOK ASK Register Settings (Rev. E)
    PDF, 532 Кб, Версия: E, Файл опубликован: 8 мар 2012
  • DN005 -- CC11xx Sensitivity versus Frequency Offset and Crystal Accuracy (Rev. C)
    PDF, 96 Кб, Версия: C, Файл опубликован: 20 авг 2009
  • DN032 -- Options for Cost Optimized CC11xx Matching
    PDF, 112 Кб, Файл опубликован: 25 авг 2010
  • DN016 -- Compact Antenna Solution for 868/915 MHz (Rev. B)
    PDF, 832 Кб, Версия: B, Файл опубликован: 20 авг 2009
  • DN019 -- Powering Low-Power RF Products (Rev. B)
    PDF, 327 Кб, Версия: B, Файл опубликован: 18 сен 2009
  • DN507 -- FEC Decoding
    PDF, 264 Кб, Файл опубликован: 28 янв 2010
    The purpose of this design note is to show how the FEC decoding implemented in HW on the CC1100, CC1100E, CC1101, CC1110Fx, CC1111Fx, CC1150, CC2500, CC2510Fx, CC2511Fx, and CC2550 can be implemented in SW. This is in particular very important for the CC430Fx device, which has the same radio as the CC1101 and CC1110/11Fx but without HW FEC included.
  • DN024 -- 868 MHz, 915 MHz and 955 MHz Monopole PCB Antenna (Rev. E)
    PDF, 1.0 Мб, Версия: E, Файл опубликован: 22 фев 2013
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • AN001 -- SRD regulations for license free transceiver operation
    PDF, 260 Кб, Файл опубликован: 1 фев 2006
  • DN033 - Mitsubishi Ceramic Antenna for 868 MHz, 915 MHz & 955 (Rev. A)
    PDF, 685 Кб, Версия: A, Файл опубликован: 14 сен 2010
  • DN023 -- 868 MHz, 915 MHz and 955 MHz Inverted F Antenna (Rev. C)
    PDF, 369 Кб, Версия: C, Файл опубликован: 30 авг 2011
  • DN018 -- Range Measurements in an Open Field Environment (Rev. A)
    PDF, 607 Кб, Версия: A, Файл опубликован: 15 апр 2008
    This design note is a general description of how to set up open field range measurements and what has to be considered. Applies to all low power RF-ICs.
  • DN002 -- Practical Sensitivity Testing
    PDF, 364 Кб, Файл опубликован: 20 дек 2006
  • AN003 -- SRD Antennas
    PDF, 358 Кб, Файл опубликован: 1 фев 2006
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Design Considerations When Using the MSP430 Graphics Library
    PDF, 475 Кб, Файл опубликован: 5 окт 2012
    LCDs are a growing commodity in todays market with products as diverse as children's toys to medical devices. Modern LCDs, along with the graphics displayed on them, are growing in complexity. A graphics library can simplify and accelerate development while creating the desired user experience. TI provides the MSP430 Graphics Library for use in developing products with the MSP430в„ў MCU. This
Серия: CC430F5125 (2)
  • Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > CC430
На английском языке: Datasheet Texas Instruments CC430F5125IRGZT
