Datasheet Texas Instruments CC2533F96RHAR — Даташит
СерияCC2533
МодельCC2533F96RHAR
Настоящее решение «система на кристалле» для приложений IEEE 802.15.4 и ZigBee с частотой 2,4 ГГц 40-VQFN от -40 до 125
An Optimized System-on-Chip Solution for 2.4-GHz IEEE 802.15.4 Remote Control Ap datasheet
PDF, 1.1 Мб, Файл опубликован: 25 июн 2010
Pin4040
Package TypeRHARHA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаF96CC2533
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
AES 128 Bit Hardware EncryptionYes
Data Rate(Max)250 kbps
Device TypeWireless MCU
FlashUp to 96 KB
Тактовая частота24 МГц
Package Size: mm2:W x L40VQFN: 36 mm2: 6 x 6(VQFN) PKG
RAM size4,4,6 KB
RX Current (Lowest)20.0 мА
Sensitivity (Best)-97 dBm
Standby Power0.4 LPM3-uA
TX Power7 dBm
TechnologyRF4CE,SimpleLink CC2x
Throughput(Max)0.25 Mbps
USB 2.0No
Wakeup Time (PD-->RX/TX)600 us
  • JTAG Emulators/ Analyzers: CC-DEBUGGER
    Debugger and Programmer for RF System-on-Chips
  • Daughter Cards: CC2533EMK
    CC2533 Evaluation Module Kit
  • Development Kits: CC2533DK-RF4CE-BA
    CC2533 RF4CE Development Kit
  • Daughter Cards: CC2531EMK
    CC2531 USB Evaluation Module Kit
  • Guide for Manufacture Testing of RF4CE Products
    PDF, 11.8 Мб, Файл опубликован: 9 янв 2015
    This application report describes a sample implementation of a manufacturing line test program for RF4CE products. It is based on RemoTI-Linux, which is the Linux host driver for CC253x RemoTI Network Processor (RNP). It includes the ability to setup a fake pairing between the remote control and target side, how to enter test mode, how to change RF parameters, and so forth. It helps customers to u
  • RemoTIв„ў Capacitive Touch Sensing (Rev. B)
    PDF, 828 Кб, Версия: B, Файл опубликован: 16 дек 2014
    As consumers become accustomed to elegant touch interfaces on a variety of devices, these capabilities are becoming more expected on a greater number of devices. The CC253x devices used in RF4CE applications provide hardware support for Capacitive Touch Sensing (Capacitive Sensing),
  • AN100 - Crystal Selection Guide (Rev. C)
    PDF, 110 Кб, Версия: C, Файл опубликован: 26 ноя 2013
    RF systems are highly dependent on accurate clocks for correct operation. A deviation in clock frequency is directly reflected as a deviation in radio frequency. This can degrade RF performance, violate legal requirements or in worst case lead to a non-functioning system. The scope of this application report is to give the design engineer a quick guide on how to design, tune and verify the
  • Voice Over Remote Control
    PDF, 112 Кб, Файл опубликован: 19 май 2016
    This application report describes the voice over RF protocol used for Texas Instruments Bluetooth В® low energy (BLE) and RF4CE remote control solutions.
  • DN041 -- Using CC253X or CC254X with Dipole PCB Antenna
    PDF, 733 Кб, Файл опубликован: 24 янв 2013
  • AN118 -- Flash programming of CC253x/4x devices
    PDF, 426 Кб, Файл опубликован: 5 сен 2012
    Application note AN118 demonstrates how to use the CC debug interface to perform various flash related tasks on CC253x / CC254x System-on-Chips. It is distributed along with a example code using a CC2530 as a programmer – but is easily ported to other devices. The application note explains in detail the example code, which covers how to enter debug mode and how to read/write/erase the flash memory
  • AN107 - Murata Balun for CC253x and CC254x, LFB182G45BG2D280 (Rev. A)
    PDF, 805 Кб, Версия: A, Файл опубликован: 26 окт 2011
  • AN081 -- Johanson Technology Balun Optimized for CC253X, CC254X, CC257X, CC853X (Rev. B)
    PDF, 456 Кб, Версия: B, Файл опубликован: 6 ноя 2012
  • ETSI EN 300 328 Blocking Test for Bluetooth Low Energy
    PDF, 2.4 Мб, Файл опубликован: 8 фев 2017
    This application report describes the setup and procedure used to measure the new ETSI EN receiver (RX) blocking test added to version v2.1.1 of the ETSI EN 300 328 harmonized standard.
  • AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)
    PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
  • DN034 -- YAGI 2.4 GHz PCB Antenna
    PDF, 1.9 Мб, Файл опубликован: 14 окт 2010
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Semiconductors > Wireless Connectivity > RF4CE
На английском языке: Datasheet Texas Instruments CC2533F96RHAR
