Datasheet LPC1776FET180,551 - NXP Даташит 8- бит микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 80 Кб SRAM USB 2.0 — Даташит
Наименование модели: LPC1776FET180,551
38 предложений от 17 поставщиков
IC MCU 32BIT 256KB FLASH 180BGA. ARM® Cortex®-M3 LPC17xx Microcontroller IC 32-Bit 120MHz 256KB (256K x 8) FLASH 180-TFBGA (12x12). Embedded...
Рутоника
LPC1776FET180,551
484 ₽
LPC1776FET180551
623 ₽
LPC1776FET180,551
643 ₽
LPC1776FET180,551
856 ₽
Производитель: NXP
Описание: 8- бит микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 80 Кб SRAM USB 2.0
data sheetСкачать Data Sheet
LPC178x/7x
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 96 kB SRAM; USB Device/Host/OTG; Ethernet; LCD; EMC
Rev.
3 -- 27 December 2011 Objective data sheet
1. General description
The LPC178x/7x is an ARM Cortex-M3 based microcontroller for embedded applications requiring a high level of integration and low power dissipation. The Cortex-M3 is a next generation core that offers better performance than the ARM7 at the same clock rate and other system enhancements such as modernized debug features and a higher level of support block integration. The Cortex-M3 CPU incorporates a 3-stage pipeline and has a Harvard architecture with separate local instruction and data buses, as well as a third bus with slightly lower performance for peripherals. The Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branches. The LPC178x/7x adds a specialized flash memory accelerator to accomplish optimal performance when executing code from flash. The LPC178x/7x
  • Упаковка: Tray
  • RoHS: да
LPC1776FET180551, LPC1776FET180 551
На английском языке: Datasheet LPC1776FET180,551 - NXP 8- bit Microcontrollers (MCU) CORTEX-M3 256 Kb FL 80 Kb SRAM USB 2.0
