Datasheet MAXQ613K-0000+ - Maxim Даташит 16- бит микроконтроллеры (MCU) Integrated схемы (ICs) встраиваемый - микроконтроллеры - Application Specific - ИС микроконтроллер 16 бит IR MOD 44TQFP — Даташит
Наименование модели: MAXQ613K-0000+
IC MCU 16BIT 48KB FLASH 44TQFP. MAXQ20S MAXQ® Microcontroller IC 16-Bit 12MHz 48KB (48K x 8) FLASH 44-TQFP (10x10). Embedded -...
MAXQ613K-0000+
Maxim
63 ₽
MAXQ613K-0000+
Maxim
143 ₽
Xinhuo Future
MAXQ613K-0000+
MAXQ613K-0000+
Maxim
Производитель: Maxim
data sheetСкачать Data Sheet
19-5320; Rev 3; 1/11
16-Bit Microcontroller with Infrared Module
General Description
The MAXQ613 is a low-power, 16-bit MAXQ® microcontroller designed for low-power applications including universal remote controls, consumer electronics, and white goods.
The device combines a powerful 16-bit RISC microcontroller and integrated peripherals including a universal synchronous/asynchronous receiver-transmitter (USART) and an SPITM master/slave communications port, along with an IR module with carrier frequency generation and flexible port I/O capable of multiplexed keypad control. The device includes 48KB of flash program memory and 1.5KB of data SRAM. Intellectual property (IP) protection is provided by a secure MMU that supports multiple application privilege levels and protects code against copying and reverse engineering. Privilege levels enable vendors to provide libraries and applications to execute on the device, while limiting access to only data and code allowed by their privilege
  • Шина данных: 16 бит
  • Ядро: MAXQ20S
  • RoHS: да
MAXQ613K0000+, MAXQ613K 0000+
На английском языке: Datasheet MAXQ613K-0000+ - Maxim 16- bit Microcontrollers (MCU) Integrated Circuits (ICs) Embedded - Microcontrollers - Application Specific - IC MCU 16 bit IR MOD 44TQFP
