Datasheet Si1002-CSB2-GM - Silicon Laboratories Даташит ВЧ микроконтроллеры (MCU) 868 МГц SNAP enabled XCVR — Даташит
Наименование модели: Si1002-CSB2-GM
9 предложений от 9 поставщиков IC RF TXRX+MCU ISM. IC RF TxRx + MCU General ISM < 1ghz='' ezradiopro='' 240mhz='' ~='' 960mhz='' 42-wfqfn='' exposed='' pad=''>. RF... | |||
| SI1002-CSB2-GM Silicon Labs | 18 963 ₽ | ||
| SI1002-CSB2-GM Silicon Labs | по запросу | ||
Производитель: Silicon Laboratories
Описание: ВЧ микроконтроллеры (MCU) 868 МГц SNAP enabled XCVR
Si1000/1/2/3/4/5
Ultra Low Power, 64/32 kB, 10-Bit ADC MCU with Integrated 240960 MHz EZRadioPRO® Transceiver Ultra Low Power: 0.9 to 3.6 V Operation - Typical sleep mode current < 0.1 µA; retains state and -
Frequency range = 240960 MHz Sensitivity = 121 dBm FSK, GFSK, and OOK modulation Max output power = +20 dBm (Si1000/1), +13 dBm (Si1002/3/4/5) RF power consumption - 18.5 mA receive - 18 mA @ +1 dBm transmit - 30 mA @ +13 dBm transmit - 85 mA @ +20 dBm transmit Data rate = 0.123 to 256 kbps Auto-frequency calibration (AFC) Antenna diversity and transmit/receive switch control Programmable packet handler TX and RX 64 byte FIFOs Frequency hopping capability On-chip crystal tuning
RAM contents over full supply range; fast wakeup of < 2 µs Less than 600 nA with RTC running Less than 1 µA with RTC running and radio state retained On-chip dc-dc converter allows operation down to 0.9 V.
Two built-in brown-out detectors cover sleep and active modes
- Упаковка: Tube
- RoHS: да
Si1002CSB2GM, Si1002 CSB2 GM
