Datasheet DS5000T-32-12 - Maxim Даташит 8- бит микроконтроллеры (MCU) — Даташит
Наименование модели: DS5000T-32-12
DS5000T-32-12
DS5000T-32-12
Производитель: Maxim
Описание: 8- бит микроконтроллеры (MCU)
data sheetСкачать Data Sheet
DS5000(T) Soft Microcontroller Module
www.maxim-ic.com
FEATURES
8-Bit 8051-Compatible Microcontroller Adapts to Task at Hand 8 or 32 kbytes of Nonvolatile RAM for Program and/or Data Memory Storage Initial Downloading of Software in End System via On-Chip Serial Port Capable of Modifying Its Own Program and/or Data Memory in End Use Crashproof Operation Maintains All Nonvolatile Resources for 10 Years in the Absence of VCC at Room Temperature Power-Fail Reset Early Warning Power-Fail Interrupt Watchdog Timer Software Security Feature Executes Encrypted Software to Prevent Unauthorized Disclosure On-Chip, Full-Duplex Serial I/O Ports Two On-Chip Timer/Event Counters 32 Parallel I/O Lines Compatible with Industry Standard 8051 Instruction Set and Pinout Optional Permanently Powered Real-Time Clock (DS5000T)
PIN ASSIGNMENT
  • Шина данных: 8 бит
  • Ядро: 8051
DS5000T3212, DS5000T 32 12
На английском языке: Datasheet DS5000T-32-12 - Maxim 8- bit Microcontrollers (MCU)
