Datasheet MAX8934GETI+ - Maxim Даташит Зарядное устройство, BATT, Вт TEMP MNTR, 3.3 В, 20TQFN — Даташит
Maxim MAX8934GETI+
Наименование модели: MAX8934GETI+
Производитель: Maxim
Описание: Зарядное устройство, BATT, Вт TEMP MNTR, 3.3 В, 20TQFN
data sheetСкачать Data Sheet
19-5296; Rev 0; 6/10
Dual-Input Linear Charger, Smart Power Selector with Advanced Battery Temperature Monitoring
General Description
The MAX8934G dual-input Li+/Li-Poly linear battery charger with Smart Power SelectorK safely charges a single Li+/Li-Poly cell in accordance with JEITA* recommendations.
The MAX8934G monitors the battery temperature (TBATT) while charging, and automatically adjusts the fast-charge current and charge termination voltage as the battery temperature varies. The MAX8934G also monitors the battery temperature while the battery is discharging, and provides a warning flag (OT) to the system in the event that the battery is over temperature. Safety region 2 is supported (see Figure 6 for details). An ultra-low IQ, always-on LDO provides an additional 3.3V supply for system power. The MAX8934G operates with either separate inputs for USB and AC adapter power, or from a single input that accepts both. All power switches for charging and switching the load between
  • Battery Charge Voltage: 4.35 В
  • Battery IC Case Style: TQFN
  • Battery Type: Li-Ion, Li-Polymer
  • Charge Current Max: 500 мА
  • Number of Series Cells: 1
  • Влагостойкость: MSL 1 - Unlimited
  • Количество выводов: 28
  • Рабочий диапазон температрур: -40°C ... +85°C
  • RoHS: да
На английском языке: Datasheet MAX8934GETI+ - Maxim CHARGER, BATT, W TEMP MNTR, 3.3 V, 20TQFN
Политика конфиденциальности
