Линейка продуктов KEEN SIDE
Datasheet G6DF4B12DC - Omron Даташит Реле MODULE, 4 X SPST-NO, 12 В — Даташит
Omron G6DF4B12DC
Наименование модели: G6DF4B12DC
Производитель: Omron
Описание: Реле MODULE, 4 X SPST-NO, 12 В
data sheetСкачать Data Sheet
Terminal Relay
G6D-F4B/G3DZ-F4B
CSM_G6D-F4B_G3DZ-F4B_DS_E_5_1
Easy-to-use, Space-saving Terminal Relay with Four-point Output
· Almost the same size as PYF Socket: 31 x 35 x 68 mm (W x H x D) · Each terminal circuit (with coil or contact) is independent from one another.
· Short Bar ensures easy connection of common and adjacent terminals. · Provided with a terminal cover that prevents electric-shock accidents. · Relay and MOS FET relay models are available. · LED operation indicator. · Built-in diode absorbs coil surge. · Mounts either on DIN track or screws. · Tool for easy mounting or removal of Relays provided. · UL, CSA, and VDE certification for standard models (VDE: G6D-F4B only).
  • Coil Current: 18.7 мА
  • Coil Resistance: 720 Ом
  • Coil Type: DC
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 3 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • External Depth: 68 мм
  • Operating Power Nom: 200 мВт
  • Внешняя ширина: 31 мм
  • Габариты: высота: 35 мм
  • Конфигурация контактов: SPST-NO
  • Способ монтажа: DIN Rail
  • Тип реле: Power
  • RoHS: да
На английском языке: Datasheet G6DF4B12DC - Omron RELAY MODULE, 4 X SPST-NO, 12 V
