Datasheet G6DF4B24DC - Omron Даташит Реле MODULE, 4 X SPST-NO, 24 В — Даташит
Наименование модели: G6DF4B24DC
![]() Реле Мощности, OMRON ELECTRONIC COMPONENTS G6DF4B24DC General Purpose Relay, G6D Series, Power, Non Latching, SPST-NO, 24VDC, 3A | |||
G6DF4B24DC Omron | 2 996 ₽ | ||
G6DF4B24DC Omron | 3 360 ₽ | ||
G6DF4B24DC | по запросу |
Производитель: Omron
Описание: Реле MODULE, 4 X SPST-NO, 24 В
Terminal Relay
G6D-F4B/G3DZ-F4B
CSM_G6D-F4B_G3DZ-F4B_DS_E_5_1
Easy-to-use, Space-saving Terminal Relay with Four-point Output
· Almost the same size as PYF Socket: 31 x 35 x 68 mm (W x H x D) · Each terminal circuit (with coil or contact) is independent from one another.
· Short Bar ensures easy connection of common and adjacent terminals. · Provided with a terminal cover that prevents electric-shock accidents. · Relay and MOS FET relay models are available. · LED operation indicator. · Built-in diode absorbs coil surge. · Mounts either on DIN track or screws. · Tool for easy mounting or removal of Relays provided. · UL, CSA, and VDE certification for standard models (VDE: G6D-F4B only).
- Coil Current: 10.5 мА
- Coil Resistance: 2.88 кОм
- Coil Type: DC
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 3 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- External Depth: 68 мм
- Operating Power Nom: 200 мВт
- Внешняя ширина: 31 мм
- Габариты: высота: 35 мм
- Конфигурация контактов: SPST-NO
- Способ монтажа: DIN Rail
- Тип реле: Power
- RoHS: да
