Datasheet G8P-1A2T-F DC48 - Omron Даташит Реле, SPST-NO, QUICK CONNECT, 48 В постоянный ток — Даташит
Наименование модели: G8P-1A2T-F DC48
Производитель: Omron
Описание: Реле, SPST-NO, QUICK CONNECT, 48 В постоянный ток
Power PCB Relay
G8PT
· Up to 30 A switching capacity in compact package.
· Available with quick-connect contact terminals for easy load connecting with either QC or PCB coil terminals. · UL Class F coil insulation standard · Minimum 6 kV Impulse Surge Withstand. · Ideal for home and industrial appliances, HVAC and many other applications. · UL recognized / CSA certified. · VDE approved. · RoHS Compliant
Ordering Information
To Order: Select the part number and add the desired coil voltage rating, (e.g., G8P-1A4P-DC12). Mounting type PCB Contact form SPST-NO SPDT PCB & Quick Connect load terminals SPST-NO SPDT Flange mount Quick Connect terminals SPST-NO SPDT Open frame Sealed with ventable nib* Open frame Sealed with ventable nib* Open frame Sealed with ventable nib* Open frame Sealed with ventable nib* Vented Vented Construction G8P-1AP G8P-1A4P G8P-1CP G8P-1C4P G8P-1ATP G8P-1A4TP G8P-1CTP G8P-1C4TP G8P-1A2T-F G8P-1C2T-F Model
- Coil Current: 19 мА
- Coil Resistance: 2.48 кОм
- Coil Type: DC
- Coil Voltage VDC Nom: 48 В
- Contact Current Max: 30 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 28 В
- External Depth: 32 мм
- Operating Power Nom: 900 мВт
- Внешняя ширина: 27.7 мм
- Габариты: высота: 28.3 мм
- Конфигурация контактов: SPST-NO
- Способ монтажа: Flange
- Тип реле: Power
- RoHS: да
- SVHC: No SVHC (18-Jun-2012)
G8P1A2TF DC48, G8P 1A2T F DC48
