Datasheet 2-1393302-2 - TE Connectivity Даташит Реле, 60 А, DPDT — Даташит
TE Connectivity 2-1393302-2
Наименование модели: 2-1393302-2
21 предложений от 10 поставщиков
Реле Мощности, Electromechanical Relay 12VDC 90Ω 120(NO)/45(NC)A SPDT (( 25.9mm 29.9mm 51.9mm)) Plug-In Power Relay Automotive
TE Connectivity
204 ₽
TE Connectivity
601 ₽
2-1393302-2
TE Connectivity
от 1 566 ₽
2-1393302-2
TE Connectivity
Производитель: TE Connectivity
Описание: Реле, 60 А, DPDT
data sheetСкачать Data Sheet
Automotive Relays Plug-in Mini ISO Relays Power Relay F4
Pin assignment similar to ISO 7588 part 1 Plug-in or PCB terminals n Also available for 42VDC applications Customized versions on request ­ 24VDC versions with contact gap >0.8mm ­ Integrated components (e.g.
resistor, diode) ­ Customized marking/color ­ Special covers (e.g. notches, release features, brackets) ­ Various contact arrangements and materials ­ For latching (bistable) version refer to Power Relay F7 A Latching or Mini Relay Latching ­ For shrouded/weatherproof dust cover versions refer to Shrouded Power Relay F4 A and VF4 A
n n
F134co_fcw1
Typical applications Cross carline up to 40A for example: ABS control, blower fans, car alarm, cooling fan, Electric Power Steering, energy management, engine control, fuel pump, heated front screen, lamps: front, rear, fog light, main switch/ supply relay, valves, wiper control.
  • Coil Resistance: 90 Ом
  • Coil Type: DC, Monostable
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 60 А
  • Contact Voltage DC Nom: 12 В
  • External Depth: 25.9 мм
  • Operating Power Nom: 1.6 Вт
  • Внешняя ширина: 25.9 мм
  • Габариты: высота: 24.9 мм
  • Конфигурация контактов: SPDT-CO
  • Способ монтажа: Quick Connect
  • Тип реле: Power
  • RoHS: да
213933022, 2 1393302 2
На английском языке: Datasheet 2-1393302-2 - TE Connectivity RELAY, 60 A, DPDT
