Datasheet LT1512IS8 - Linear Technology Даташит Зарядное устройство, BATT, 1.5 А, 500 кГц, 8SOIC — Даташит
Linear Technology LT1512IS8
Наименование модели: LT1512IS8
41 предложений от 20 поставщиков
Микросхема Чип управления батареи, Battery Charger Lead-Acid/Li-Ion/NiCD/NiMH 750mA 30V 8Pin SOIC N
727GS
LT1512IS8#PBF
от 271 ₽
LT1512IS8#PBF
Hi-Tech Circuit Group
LT1512IS8#TRPBF
LT1512IS8TR
Производитель: Linear Technology
Описание: Зарядное устройство, BATT, 1.5 А, 500 кГц, 8SOIC
data sheetСкачать Data Sheet
LT1512 SEPIC Constant-Current/ Constant-Voltage Battery Charger FEATURES
n n n n n n n
DESCRIPTION
The LT®1512 is a 500kHz current mode switching regulator specially configured to create a constant-current/constantvoltage battery charger.
In addition to the usual voltage feedback node, it has a current sense feedback circuit for accurately controlling output current of a flyback or SEPIC (Single-Ended Primary Inductance Converter) topology charger. These topologies allow the current sense circuit to be ground referred and completely separated from the battery itself, simplifying battery switching and system grounding problems. In addition, these topologies allow charging even when the input voltage is lower than the battery voltage. Maximum switch current on the LT1512 is 1.5A. This allows battery charging currents up to 1A for a single lithium-ion cell. Accuracy of 1% in constant-voltage mode is perfect for lithium battery applications. Charging current can be easily programmed for a
  • Battery Charge Voltage: 30 В
  • Battery IC Case Style: SOIC
  • Battery Type: Lithium, NiCd, NiMH
  • Charge Current Max: 1 А
  • Number of Series Cells: 12
  • Влагостойкость: MSL 1 - Unlimited
  • Количество выводов: 8
  • Рабочий диапазон температрур: -40°C ... +85°C
  • RoHS: да
  • SVHC: No SVHC (18-Jun-2012)
На английском языке: Datasheet LT1512IS8 - Linear Technology CHARGER, BATT, 1.5 A, 500 kHz, 8SOIC
