Datasheet 5-1393302-1 - TE Connectivity Даташит Реле, 20 А, SPST — Даташит
Наименование модели: 5-1393302-1
Купить 5-1393302-1 на РадиоЛоцман.Цены — от 466 до 1 785 ₽22 предложений от 13 поставщиков Реле Мощности, TE CONNECTIVITY 5-1393302-1 Automotive Relay, SPDT, 24VDC, 40A, Power Relay F4 Series, Through Hole, Solder | |||
| 5-1393302-1 TE Connectivity | 581 ₽ | ||
| 5-1393302-1 TE Connectivity | от 1 512 ₽ | ||
| 5-1393302-1 TE Connectivity | от 1 785 ₽ | ||
Производитель: TE Connectivity
Описание: Реле, 20 А, SPST
Automotive Relays Plug-in Mini ISO Relays Power Relay F4
Pin assignment similar to ISO 7588 part 1 Plug-in or PCB terminals n Also available for 42VDC applications Customized versions on request 24VDC versions with contact gap >0.8mm Integrated components (e.g.
resistor, diode) Customized marking/color Special covers (e.g. notches, release features, brackets) Various contact arrangements and materials For latching (bistable) version refer to Power Relay F7 A Latching or Mini Relay Latching For shrouded/weatherproof dust cover versions refer to Shrouded Power Relay F4 A and VF4 A
n n
F134co_fcw1
Typical applications Cross carline up to 40A for example: ABS control, blower fans, car alarm, cooling fan, Electric Power Steering, energy management, engine control, fuel pump, heated front screen, lamps: front, rear, fog light, main switch/ supply relay, valves, wiper control.
- Coil Resistance: 268 Ом
- Coil Type: DC, Monostable
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 20 А
- Contact Voltage DC Nom: 24 В
- External Depth: 25.9 мм
- Operating Power Nom: 2.1 Вт
- Внешняя ширина: 25.9 мм
- Габариты: высота: 24.9 мм
- Конфигурация контактов: SPDT-CO
- Способ монтажа: Quick Connect
- Тип реле: Power
- RoHS: да
513933021, 5 1393302 1
