Datasheet LT1720CMS8 - Linear Technology Даташит Компаратор, сдвоенный, 4.5 нс, MSOP-8 — Даташит
Наименование модели: LT1720CMS8
![]() 35 предложений от 22 поставщиков Микросхема Компаратор, Dual/Quad, 4.5ns, Single Supply 3V/5V Comparators with Rail-to-Rail Outputs | |||
LT1720CMS8#TRPBF Linear Technology | от 308 ₽ | ||
LT1720CMS8#TRPBF Linear Technology | от 339 ₽ | ||
LT1720CMS8 Analog Devices | 1 569 ₽ | ||
LT1720CMS8 | по запросу |
Производитель: Linear Technology
Описание: Компаратор, сдвоенный, 4.5 нс, MSOP-8
FEATURES
n n n n n n n n n
LT1720/LT1721 Dual/Quad, 4.5ns, Single Supply 3V/5V Comparators with Rail-to-Rail Outputs DESCRIPTION
The LT®1720/LT1721 are UltraFastTM dual/quad comparators optimized for single supply operation, with a supply voltage range of 2.7V to 6V.
The input voltage range extends from 100mV below ground to 1.2V below the supply voltage. Internal hysteresis makes the LT1720/LT1721 easy to use even with slow moving input signals. The rail-to-rail outputs directly interface to TTL and CMOS. Alternatively, the symmetric output drive can be harnessed for analog applications or for easy translation to other single supply logic levels. The LT1720 is available in three 8-pin packages; three pins per comparator plus power and ground. In addition to SO and MSOP packages, a 3mm Ч 3mm low profile (0.8mm) dual fine pitch leadless package (DFN) is available for space limited applications. The LT1721 is available in the 16-pin SSOP and S packages. The pinouts of the LT1720/LT1721
- Output Compatibility: CMOS, TTL
- Время отклика: 4.5 нс
- Диапазон напряжения питания: 2.7 В ... 6 В
- Количество выводов: 8
- Количество компараторов: 2
- Тип компаратора: High Speed
- Тип корпуса: MSOP
- Ток потребления: 4 мА
