Datasheet NCP2811AMTTXG - ON Semiconductor Даташит Аудио усилители HEADSET аудио усилитель — Даташит
Наименование модели: NCP2811AMTTXG
Купить NCP2811AMTTXG на РадиоЛоцман.Цены — от 26 до 127 ₽10 предложений от 10 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Headphone 2CH Stereo 0.11W Class-AB 12Pin WQFN EP T/R | |||
| NCP2811AMTTXG ON Semiconductor | 26 ₽ | ||
| NCP2811AMTTXG ON Semiconductor | 65 ₽ | ||
| NCP2811AMTTXG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: Аудио усилители HEADSET аудио усилитель
NCP2811 NOCAPt Advanced Stereo Headphone Amplifier
NCP2811 is a dual audio power amplifier designed for portable communication device applications such as mobile phones.
This part is capable of delivering 27 mW of continuous average power into a 16 load from a 2.7 V power supply with a THD+N of 1%. Based on the power supply delivered to the device, an internal power management block generates a symmetrical positive and negative voltage. Thus, the internal amplifiers provide outputs referenced to Ground. In this True Ground configuration, the two external heavy coupling capacitors can be removed. It offers significant space and cost savings compared to a typical stereo application. NCP2811 is available with an external adjustable gain (version A), or with an internal gain of -1.5 V/V (version B). It reaches a superior -100 dB PSRR and noise floor. Thus, it offers high fidelity audio sound, as well as a direct connection to the battery. It contains circuitry to prevent from "Pop & Click
- Вид монтажа: SMD/SMT
- Выходная мощность: 27 мВт
- Диапазон напряжения питания: - 0.3 В ... + 6 В
- Максимально возможное усиление: - 1.5 V/V
- Продукт: General Purpose аудио Amplifiers
- Рабочее напряжение питания: 2.7 В ... 5 В
- Суммарные нелинейные искажения + шум: 1 %
- Тип выхода: 2-Channel Stereo
- Тип корпуса: WQFN-12
- Ток потребления: 6 мА
- Упаковка: Reel
- RoHS: да
