Datasheet Texas Instruments LM4675SD/NOPB — Даташит
СерияLM4675
МодельLM4675SD/NOPB
Ультранизкий уровень электромагнитных помех, без фильтра, 2,65 Вт, моно, усилитель мощности звука класса D, с расширенным спектром 8-WSON
Ultra-Low EMI, Fltrles, 2.65W, Mono, ClassD Audio Pwr Amp w/Sprd Spectrum datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 1 май 2013
Package TypeNGQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
МаркировкаL4675
Width (мм)3
Length (мм)3
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Analog Supply (V)2.4 Max
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceHardware
Iq per channel(Typ)2.8 мА
Iq(Max)3.9 мА
Iq(Typ)2.8 мА
Load(Min)4 ohms
Выходная мощность2.7 W
PSRR82 дБ
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Pin/Package8WSON, 9DSBGA
Shutdown Current (ISD)0.01 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.03 %
  • Evaluation Modules & Boards: LM4675SDBD
    Ultra-Low EMI, Filterless, 2.65W, Mono, Class D Audio Power Amplifier (LLP-8)
  • Evaluation Modules & Boards: LM4675TLBD
    Ultra-Low EMI, Filterless, 2.65W, Mono, Class D Audio Power Amplifier (Micro SMD-9)
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
Серия: LM4675 (4)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments LM4675SD/NOPB
