Datasheet Texas Instruments LM386N-4/NOPB — Даташит
СерияLM386
МодельLM386N-4/NOPB
Широкополосный маломощный аудиоусилитель с внутренним усилением 8-PDIP от 0 до 70
LM386 Low Voltage Audio Power Amplifier datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 30 май 2017
38 предложений от 18 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM386N-4/NOPB Audio Power Amplifier, AB, 1Channel, 1W, 5V to 18V, DIP, 8Pins
Microfind
LM386N-4/NOPB
46 ₽
LM386N-4/NOPB
52 ₽
LM386N-4/NOPB
52 ₽
LM386N-4/NOPB
Pin88
Package TypePP
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-TR-PDIP-T
Package QTY4040
CarrierTUBETUBE
МаркировкаLM386N-4
Width (мм)6.356.35
Length (мм)9.819.81
Thickness (мм)3.93.9
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Analog Supply (V)20 Max
АрхитектураClass AB
Audio Input TypeAnalog Input
Control InterfaceHardware
Iq per channel(Typ)4 мА
Iq(Max)4 мА
Iq(Typ)4 мА
Load(Min)4 ohms
Выходная мощность0.325 W
PSRR50 дБ
Package GroupPDIP
Pin/Package8PDIP, 8SOIC, 8VSSOP
Speaker ChannelsMono Max
THD + N @ 1 kHz0.2 %
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
  • Calculating Gain for Audio Amplifiers (Rev. A)
    PDF, 238 Кб, Версия: A, Файл опубликован: 1 сен 2005
    This application report explains the different types of audio power amplifier configurations, such as the single-ended (SE), the bridge-tied load (BTL), and the fully differential audio amplifier. Each configuration is illustrated with a block diagram, gain equations, and an example using realistic scenarios to illustrate to engineers how to calculate the gain of their audio amplifier.
  • AN-263 Sine Wave Generation Techniques (Rev. C)
    PDF, 747 Кб, Версия: C, Файл опубликован: 22 апр 2013
    This application note describes the sine wave generation techniques to control frequency amplitude anddistortion levels.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
LM386N4/NOPB, LM386N 4/NOPB
На английском языке: Datasheet Texas Instruments LM386N-4/NOPB
