Datasheet Texas Instruments TPA2010D1YZFR — Даташит
СерияTPA2010D1
МодельTPA2010D1YZFR
Моноусилитель звука класса D мощностью 2,5 Вт с регулируемым коэффициентом усиления (TPA2010) 9-DSBGA от -40 до 85
TPA2010D1 2.5-W Mono Filter-Free Class-D Audio Power Amplifier datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 30 ноя 2015
Pin9
Package TypeYZF
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
МаркировкаAK0
Width (мм)1.75
Length (мм)1.75
Pitch (мм).5
Max Height (мм).625
Analog Supply (V)5.5 Min
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceHardware
Iq per channel(Typ)3.4 мА
Iq(Max)4.9 мА
Iq(Typ)3.4 мА
Load(Min)4 ohms
Выходная мощность2.5 W
PSRR75 дБ
Package GroupDSBGA
Pin/Package9DSBGA
Shutdown Current (ISD)0.5 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.18 %
  • Evaluation Modules & Boards: TPA2010D1EVM
    TPA2010D1 Evaluation Module (EVM)
  • Measuring Class-D Amplifiers for Audio Speaker Overstress Testing
    PDF, 175 Кб, Файл опубликован: 28 окт 2005
    This application report presents the results of an experiment conducted to demonstrate how to address the two most common concerns regarding speaker damage using Class-D amplifiers.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2010D1 (4)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2010D1YZFR
