Datasheet SCY99091FCT2G - ON Semiconductor Даташит Аудио усилители 1.0 WATT аудио усилитель — Даташит
Наименование модели: SCY99091FCT2G
Микросхема Усилитель звуковой частоты, Voltage Detector Series with Programmable Delay
SCY99091FCT2G
8.59 ₽
SCY99091FCT2G
LifeElectronics
SCY99091FCT2G
SCY99091FCT2G
Производитель: ON Semiconductor
Описание: Аудио усилители 1.0 WATT аудио усилитель
data sheetСкачать Data Sheet
NCP302, NCP303 Voltage Detector Series with Programmable Delay
The NCP302 and NCP303 series are second generation ultra-low current voltage detectors that contain a programmable time delay generator.
These devices are specifically designed for use as reset controllers in portable microprocessor based systems where extended battery life is paramount. Each series features a highly accurate undervoltage detector with hysteresis and an externally programmable time delay generator. This combination of features prevents erratic system reset operation. The NCP302 series consists of complementary output devices that are available with either an active high or active low reset. The NCP303 series has an open drain N-Channel output with an active low reset output.
Features http://onsemi.com MARKING DIAGRAM
5 5 1 xxx A Y W G TSOP-5/ SOT23-5 CASE 483 xxx AYWG G 1
  • Упаковка: Reel
  • RoHS: да
На английском языке: Datasheet SCY99091FCT2G - ON Semiconductor Audio Amplifiers 1.0 WATT AUDIO AMP
