Datasheet Texas Instruments OPA134UAG4 — Даташит
СерияOPA134
МодельOPA134UAG4
Высокопроизводительные операционные усилители звука SoundPlus™ 8-SOIC от -40 до 85
OPAx134 SoundPlusв„ў High Performance Audio Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 28 окт 2015
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
МаркировкаOPA134UA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesBurr-Brownв„ў Audio
АрхитектураFET
CMRR(Min)86 дБ
CMRR(Typ)100 дБ
GBW(Typ)8 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)5 мА
Iq per channel(Typ)4 мА
Количество каналов1
Offset Drift(Typ)2 uV/C
Output Current(Typ)40 мА
Rail-to-RailNo
Slew Rate(Typ)20 V/us
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
  • Precision Absolute Value Circuits
    PDF, 100 Кб, Файл опубликован: 2 окт 2000
    You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA134UAG4
