Datasheet Texas Instruments TAS5122DCA — Даташит
СерияTAS5122
МодельTAS5122DCA
Мощность цифрового стереоусилителя мощностью 50 Вт 56-HTSSOP от 0 до 70
TAS5122: 30-W Stereo Digital Amplifier Power Stage datasheet
PDF, 775 Кб, Версия: E, Файл опубликован: 15 дек 2004
Pin56
Package TypeDCA
Industry STD TermHTSSOP
Package QTY35
МаркировкаTAS5122
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Audio Input TypePWM
Control InterfaceHardware
Выходная мощность30 W
Power Stage Supply(Max)25.5 В
Power to Bridge Tied Load(Max)37 W
SNR95 дБ
Speaker Channels2 Max
THD + N @ 1 kHz0.05 %
  • TAS5028-5122C6EVM Application Report
    PDF, 1.5 Мб, Файл опубликован: 17 янв 2005
  • TAS5508-5122C6EVM Application Report (Rev. A)
    PDF, 1.5 Мб, Версия: A, Файл опубликован: 26 апр 2006
  • Voltage Spike Measurement Technique and Specification (Rev. A)
    PDF, 179 Кб, Версия: A, Файл опубликован: 13 ноя 2003
    As an extension to the voltage ratings given in the Absolute Maximum Ratings section of the TAS5111, TAS5112, TAS5121, and TAS5122 data sheets, this application note gives a more explicit description of the maximum limit for peak voltage vs. time on the BST and OUT pins. Additionally, a measurement technique and test setup is described and application design guidelines given on how to avoid exceed
  • Power Supply Recommendations for DVD Receivers
    PDF, 153 Кб, Файл опубликован: 4 май 2005
    Selecting the optimal power supply for a non feed back digital amplifier can bechallenging. Music is dynamic, so the power consumption is changing dramatically,from almost zero to maximum within a few ms.Designing the power supply so powerful that it can deliver the total amplifier outputpower continuously is too costly and usually unnecessary.Designing the power supply too small gives p
  • PSRR for Purepath Digital Audio Amplifiers
    PDF, 159 Кб, Файл опубликован: 15 апр 2005
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5122 (3)
  • Semiconductors > Audio > High-Power Audio Amplifiers (>50W) > PWM Input Class-D
На английском языке: Datasheet Texas Instruments TAS5122DCA
