Datasheet Texas Instruments THS4541IRGTR — Даташит
СерияTHS4541
МодельTHS4541IRGTR
Высокоскоростной усилитель дифференциального ввода-вывода 16-VQFN от -40 до 125
THS4541 Negative Rail Input, Rail-to-Rail Output, Precision, 850-MHz Fully Differential Amplifier datasheet
PDF, 2.2 Мб, Версия: A, Файл опубликован: 30 сен 2014
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаHS4541
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
2nd Harmonic140 dBc
3rd Harmonic140 dBc
@ MHz0.1
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураFully Differential,Voltage FB
BW @ Acl620 МГц
CMRR(Min)85 дБ
CMRR(Typ)100 дБ
GBW(Typ)850 МГц
Input Bias Current(Max)13000000 pA
Iq per channel(Max)10.5 мА
Iq per channel(Typ)10.1 мА
Количество каналов1
Offset Drift(Typ)0.5 uV/C
Output Current(Typ)100 мА
Package GroupVQFN
Package Size: mm2:W x L16VQFN: 9 mm2: 3 x 3(VQFN) PKG
Rail-to-RailIn to V-,Out
Slew Rate(Typ)1500 V/us
Total Supply Voltage(Max)5.4 +5V=5, +/-5V=10
Vn at 1kHz(Typ)33 нВ/rtГц
Vn at Flatband(Typ)2.2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.45 мВ
  • Evaluation Modules & Boards: THS4541RGTEVM
    THS4541 Evaluation Module in RGT Package
  • Evaluation Modules & Boards: DEV-ADC34J22
    DEV-ADC34J22 Evaluation Module
  • Input impedance matching with fully differential amplifiers
    PDF, 643 Кб, Файл опубликован: 22 окт 2008
  • Using single-supply fully diff. amps with neg. input voltages to drive ADCs
    PDF, 105 Кб, Файл опубликован: 15 ноя 2010
  • Design for a Wideband Differential Transimpedance DAC Output (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
    High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options
Серия: THS4541 (4)
На английском языке: Datasheet Texas Instruments THS4541IRGTR
