Datasheet Linear Technology LTC2051HVCMS8#TRPBF — Даташит
СерияLTC2051HV
МодельLTC2051HVCMS8#TRPBF
Операционные усилители с двойным нулевым дрейфом
Datasheet LTC2051, LTC2052
PDF, 148 Кб, Язык: анг., Файл закачен: 31 июл 2016, Страниц: 12
Dual/Quad Zero-Drift Operational Amplifiers
IC OPAMP ZERO-DRIFT 2 CIRC 8MSOP. Zero-Drift Amplifier 2 Circuit Rail-to-Rail 8-MSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
Рутоника
LTC2051HVCMS8#TRPBF
281 ₽
Элитан
LTC2051HVCMS8#TRPBF
1 046 ₽
LTC2051HVCMS8 TRPBF
SUV System
LTC2051HVCMS8#TRPBF
КорпусMS-8
Код корпусаMS8
Индекс корпуса05-08-1660
Количество каналов2
Частота единичного усиления GBW3 МГц
Av Min Stable1 V/V
Avol80 дБ
CMRR130 дБ
Cload100 пФ
Design ToolsLTspice Model
Экспортный контрольнет
Ibias0.025 нА
Ios0.00015 мкА
Iout10 мА
Isupply0.85 мА
LF Enoise1.5 µVPP
Over-the-Topнет
PSRR130 дБ
Rail-to-RailIn to V-,Output
Rail-to-Rail Inнет
Rail-to-Rail Outда
SR2 В/мс
Shutdownда
Single Supplyда
Ts (0.1%)2000 нс
ТипZD
Voh (from V+)0.02 В
Vol (from V-)0.002 В
Vos0.0005 мВ
Vos TC0.01 мВ/C
Vs макс.11 В
Vs мин.2.7 В
LTC2051 LTC2051 LTC2052 LTC2052 LTC2052HV
  • Delta Sigma ADC Bridge Measurement Techniques &mdash AN96
    PDF, 232 Кб, Файл опубликован: 17 янв 2005
    AN96 features several applications that demonstrate how to take full advantage of Linear Technology's delta sigma ADCs when interfacing to sensors. In many cases, signal conditioning can be greatly simplified or eliminated completely. This note explains where it is appropriate to use amplifiers and how to optimize amplifier gain. Also included are discussions on measuring effective number of bits (ENOB) and the relationship to instrument performance, frequency response of delta sigma ADCs, and test techniques. C source code for all of the applications is included to aid firmware development.
Статьи
  • Low Power, DC Accurate Drivers for 18-Bit ADCs &mdash LT Journal
    PDF, 3.4 Мб, Файл опубликован: 9 июл 2013
  • Zero-Drift Operational Amplifier Family in Small-Footprint Packages Features 3µV Maximum DC Offset and30nV/°C Maximum Drift &mdash LT Journal
    PDF, 186 Кб, Файл опубликован: 1 ноя 2000
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Zero-Drift Amplifiers | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | Rail-to-Rail Amplifiers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
LTC2051HVCMS8TRPBF, LTC2051HVCMS8 TRPBF
На английском языке: Datasheet Linear Technology LTC2051HVCMS8#TRPBF
