Datasheet Linear Technology LTC2051HVIMS8#PBF — Даташит
Серия | LTC2051HV |
Модель | LTC2051HVIMS8#PBF |
Операционные усилители с двойным нулевым дрейфом
Datasheet LTC2051, LTC2052
PDF, 148 Кб, Язык: анг., Файл закачен: 31 июл 2016, Страниц: 12
Dual/Quad Zero-Drift Operational Amplifiers
![]() 38 предложений от 18 поставщиков Микросхема Буферный усилитель, LTC2051 - Dual Zero-Drift Operational Amplifiers; Package: MSOP; Pins: 8; Temperature Range: -40℃ to 85℃ | |||
LTC2051HVIMS8#PBF Analog Devices | 199 ₽ | ||
LTC2051HVIMS8 Linear Technology | 205 ₽ | ||
LTC2051HVIMS8 | от 1 235 ₽ | ||
LTC2051HVIMS8#TRPBF | по запросу |
Корпус | MS-8 |
Код корпуса | MS8 |
Индекс корпуса | 05-08-1660 |
Количество каналов | 2 |
Частота единичного усиления GBW | 3 МГц |
Av Min Stable | 1 V/V |
Avol | 80 дБ |
CMRR | 130 дБ |
Cload | 100 пФ |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Ibias | 0.025 нА |
Ios | 0.00015 мкА |
Iout | 10 мА |
Isupply | 0.85 мА |
LF Enoise | 1.5 µVPP |
Over-the-Top | нет |
PSRR | 130 дБ |
Rail-to-Rail | In to V-,Output |
Rail-to-Rail In | нет |
Rail-to-Rail Out | да |
SR | 2 В/мс |
Shutdown | да |
Single Supply | да |
Ts (0.1%) | 2000 нс |
Тип | ZD |
Voh (from V+) | 0.02 В |
Vol (from V-) | 0.002 В |
Vos | 0.0005 мВ |
Vos TC | 0.01 мВ/C |
Vs макс. | 11 В |
Vs мин. | 2.7 В |
LTC2051 LTC2051 LTC2052 LTC2052 LTC2052HV
- Delta Sigma ADC Bridge Measurement Techniques &mdash AN96PDF, 232 Кб, Файл опубликован: 17 янв 2005
AN96 features several applications that demonstrate how to take full advantage of Linear Technology's delta sigma ADCs when interfacing to sensors. In many cases, signal conditioning can be greatly simplified or eliminated completely. This note explains where it is appropriate to use amplifiers and how to optimize amplifier gain. Also included are discussions on measuring effective number of bits (ENOB) and the relationship to instrument performance, frequency response of delta sigma ADCs, and test techniques. C source code for all of the applications is included to aid firmware development.Выписка из документа
Статьи
- Low Power, DC Accurate Drivers for 18-Bit ADCs &mdash LT JournalPDF, 3.4 Мб, Файл опубликован: 9 июл 2013Выписка из документа
- Zero-Drift Operational Amplifier Family in Small-Footprint Packages Features 3µV Maximum DC Offset and30nV/°C Maximum Drift &mdash LT JournalPDF, 186 Кб, Файл опубликован: 1 ноя 2000Выписка из документа
Серия: LTC2051HV (20)
- LTC2051HVCDD#PBF LTC2051HVCDD#TRPBF LTC2051HVCMS10#PBF LTC2051HVCMS10#TRPBF LTC2051HVCMS8#PBF LTC2051HVCMS8#TRPBF LTC2051HVCS8#PBF LTC2051HVCS8#TRPBF LTC2051HVHMS8#PBF LTC2051HVHMS8#TRPBF LTC2051HVHS8#PBF LTC2051HVHS8#TRPBF LTC2051HVIDD#PBF LTC2051HVIDD#TRPBF LTC2051HVIMS10#PBF LTC2051HVIMS10#TRPBF LTC2051HVIMS8#PBF LTC2051HVIMS8#TRPBF LTC2051HVIS8#PBF LTC2051HVIS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Zero-Drift Amplifiers | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
LTC2051HVIMS8PBF, LTC2051HVIMS8 PBF
