Datasheet Linear Technology LTC1050ACN8#PBF — Даташит
СерияLTC1050
МодельLTC1050ACN8#PBF
Прецизионный операционный усилитель с нулевым дрейфом и внутренними конденсаторами
Datasheet LTC1050
PDF, 232 Кб, Язык: анг., Файл закачен: 31 июл 2016, Страниц: 16
Precision Zero-Drift Operational Amplifier with Internal Capacitors
26 предложений от 13 поставщиков
, Precision Zero-Drift Operational Amplifier with Internal Capacitors
LTC1050ACN8#PBF
от 172 ₽
Элитан
LTC1050ACN8
1 308 ₽
LTC1050ACN8#PBF
LTC1050ACN8
КорпусN-8
Код корпусаN
Индекс корпуса05-08-1510 (N8)
Количество каналов1
Частота единичного усиления GBW2.5 МГц
Av Min Stable1 V/V
Avol100 дБ
CMRR140 дБ
Cload100 пФ
Demo BoardsDC417B
Design ToolsLTspice Model
Enoise Density90 нВ/rtГц
Экспортный контрольнет
Ibias0.01 нА
Inoise0.0018 пА/rtГц
Ios0.00002 мкА
Iout6 мА
Isupply1 мА
LF Enoise1.6 µVPP
Over-the-Topнет
PSRR140 дБ
Rail-to-RailIn to V-,Output
Rail-to-Rail Inнет
Rail-to-Rail Outда
SR4 В/мс
Shutdownнет
Single Supplyда
ТипZD
VinCM High (from V+)2.3 В
Voh (from V+)0.05 В
Vol (from V-)0.05 В
Vos0.0005 мВ
Vos TC0.01 мВ/C
Vs макс.18 В
Vs мин.4.75 В
  • Application Considerations for an Instrumentation Lowpass Filter &mdash AN20
    PDF, 2.8 Мб, Файл опубликован: 1 сен 1986
    Discusses the principles of operation of the LTC1062 and helpful hints for its application. Various application circuits are explained in detail with focus on how to cascade two LTC1062s and how to obtain notches. Noise and distortion performance are fully illustrated.
  • Thermocouple Measurement &mdash AN28
    PDF, 988 Кб, Файл опубликован: 1 фев 1988
    Considerations for thermocouple-based temperature measurement are discussed. A tutorial on temperature sensors summarizes performance of various types, establishing a perspective on thermocouples. Thermocouples are then focused on. Included are sections covering cold-junction compensation, amplifier selection, differential/isolation techniques, protection, and linearization. Complete schematics are given for all circuits. Processor- based linearization is also presented with the necessary software detailed.
  • Using the LTC Op Amp Macromodels &mdash AN48
    PDF, 297 Кб, Файл опубликован: 8 ноя 1991
    LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.
  • Linear Technology Magazine Circuit Collection, Volume III &mdash AN67
    PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
    Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.
  • A Collection of Differential to Single-Ended Signal Conditioning Circuits for Use with the LTC2400, a 24-Bit No Latency Delta Sigma ADC in an SO-8 &mdash AN78
    PDF, 177 Кб, Файл опубликован: 7 авг 1999
    This application note describes six low power differential-tosingle- ended signal conditioning circuits for the LTC2400 No Latency ΔΣTM 24-bit ADC. These circuits offer the customer a number of choices for conditioning differential input signals as low as 5mV to as high as ±2.5V, as well as operation on a single 5V or ±5V supplies. Each circuit description also covers circuit design and implementation techniques that can help preserve the LTC2400's inherently high effective resolution. AN78 concludes with two circuits for digitizing temperature when using an RTD or Type S thermocouple.
Design Notes
  • LTC2400 High Accuracy Differential to Single-Ended Differential to Single-Ended Converter Has Very High Uncalibrated Accuracy and Low Offset and Drift &mdash Design Solutions 1
    PDF, 39 Кб, Файл опубликован: 1 апр 1999
  • High Accuracy, Differential to Single-Ended Conversion for Wide Range Bipolar Input Signals Bipolar Differential to Single-Ended Converter Drives the LTC2400's Input Rail-to-Rail &mdash Design Solutions 4
    PDF, 37 Кб, Файл опубликован: 1 апр 1999
  • LTC2400 Differential to Single-Ended Converter for Single 5V Supply This Converter Has High Accuracy, Very Low Offset and Offset Drift, Rail-to-Rail Input Common Mode Range and is Live at Zero &mdash Design Solutions 6
    PDF, 62 Кб, Файл опубликован: 1 май 1999
  • LTC2400 High Accuracy Differential to Single-Ended Converter for В±5V Supplies &mdash DN207
    PDF, 76 Кб, Файл опубликован: 1 июл 1999
  • 24-Bit ADC Measures from DC to Daylight &mdash DN219
    PDF, 76 Кб, Файл опубликован: 1 дек 1999
  • Ultra Low Noise Op Amp Combines Chopper and Bipolar Op Amps &mdash DN36
    PDF, 99 Кб, Файл опубликован: 1 июл 1990
  • Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42
    PDF, 70 Кб, Файл опубликован: 1 дек 1990
  • Temperature Measurement Using Data Acquisition Systems &mdash DN5
    PDF, 77 Кб, Файл опубликован: 1 мар 1989
  • Chopper Amplifiers Complement a DC Accurate Low-Pass Filter &mdash DN9
    PDF, 369 Кб, Файл опубликован: 1 мар 1988
Статьи
  • LTC2400 Differential Bridge Digitizers &mdash LT Journal
    PDF, 120 Кб, Файл опубликован: 1 июн 1999
  • Consider New Precision Amplifiers for Updated Industrial Equipment Designs &mdash LT Journal
    PDF, 154 Кб, Файл опубликован: 1 сен 2009
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Rail-to-Rail Amplifiers | Precision Amplifiers (Vos | Zero-Drift Amplifiers | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | High Voltage Amplifiers (>12V)
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
LTC1050ACN8PBF, LTC1050ACN8 PBF
На английском языке: Datasheet Linear Technology LTC1050ACN8#PBF
Публикации по теме
