Datasheet Texas Instruments OPA2277PG4 — Даташит
СерияOPA2277
МодельOPA2277PG4
10ВµV, 0.1ВµV/ЛљC, High-Precision, Low-Power Operational Amplifier 8-PDIP
OPAx277 High Precision Operational Amplifiers datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 30 июн 2015
Микросхема Буферный усилитель, 10μV, 0.1μV/˚C, High-Precision, Low-Power Operational Amplifier 8-PDIP
OPA2277PG4
286 ₽
OPA2277PG4
567 ₽
OPA2277PG4
OPA2277PG4
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаOPA2277P
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)130 дБ
CMRR(Typ)140 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)1000 pA
Iq per channel(Max)0.825 мА
Iq per channel(Typ)0.79 мА
Количество каналов2
Offset Drift(Typ)0.1 uV/C
Output Current(Typ)35 мА
Package GroupPDIP
Rail-to-RailIn,Out
Slew Rate(Typ)0.8 V/us
Total Supply Voltage(Min)4 +5V=5, +/-5V=10
Vn at 1kHz(Typ)8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.025 мВ
RoHSНе совместим
  • OPA277 OPA2277 OPA4277 EMI Immunity Performance (Rev. A)
    PDF, 88 Кб, Версия: A, Файл опубликован: 31 окт 2012
  • High-Voltage Signal Conditioning for Low Voltage ADCs
    PDF, 135 Кб, Файл опубликован: 15 июн 2004
    Analog designers are frequently required to develop circuits that convert high-voltage signals to levels acceptable for low-voltage data converters. This paper describes several solutions for this common task using modern amplifiers and typical power supplies. Five examples of conditioning ±10V bipolar signals for low-voltage single-rail analog-to-digital converters(ADCs) are presented:
  • Precision Absolute Value Circuits
    PDF, 100 Кб, Файл опубликован: 2 окт 2000
    You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2277PG4
