Datasheet Texas Instruments LM358PWR — Даташит
СерияLM358
МодельLM358PWR
Двойные операционные усилители 8-TSSOP от 0 до 70
Datasheet LM158, LM158A, LM258, LM258A, LM358, LM358A, LM2904, LM2904V
PDF, 2.0 Мб, Версия: U, Файл опубликован: 7 янв 2017, Страниц: 43
Dual Operational Amplifiers
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Pitch (мм)0.65
Max Height (мм)1.2
АрхитектураBipolar
CMRR(Min)65 дБ
CMRR(Typ)80 дБ
Основные особенностиCost Optimized
GBW(Typ)0.7 МГц
Input Bias Current(Max)150000 pA
Iq per channel(Max)0.6 мА
Iq per channel(Typ)0.35 мА
Количество каналов2
Offset Drift(Typ)7 uV/C
Output Current(Typ)30 мА
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
Rail-to-RailIn to V-
Slew Rate(Typ)0.3 V/us
Total Supply Voltage(Max)32 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)40 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)7 мВ
  • Evaluation Modules & Boards: DUAL-DIYAMP-EVM
    Dual Channel Universal Do-It-Yourself (DIY) Amplifier Circuit Evaluation Module
  • AN-116 Use the LM158/LM258/LM358 Dual Single Supply Op Amp (Rev. B)
    PDF, 313 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note discusses the use of the LM158/LM258/LM358 dual op amp when operated from asingle supply.
  • AN-30 Log Converters (Rev. B)
    PDF, 370 Кб, Версия: B, Файл опубликован: 1 май 2013
    One of the most predictable non-linear elements commonly available is the bipolar transistor. Therelationship between collector current and emitter base voltage is precisely logarithmic from currentsbelow one picoamp to currents above one milliamp. Using a matched pair of transistors and integratedcircuit operational amplifiers it is relatively easy to construct a linear to logarithmic conv
  • AN-278 Designing with a New Super Fast Dual Norton Amplifier (Rev. B)
    PDF, 867 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides new design ideas and discusses the positive impact of designing with theDual Norton amplifier.
  • AN-79 IC Preamplifier Challenges Choppers on Drift (Rev. B)
    PDF, 940 Кб, Версия: B, Файл опубликован: 1 май 2013
    Since the introduction of monolithic IC amplifiers there has been a continual improvement in DC accuracy.Bias currents have been decreased by 5 orders of magnitude over the past 5 years. Low offset voltagedrift is also necessary in a high accuracy circuits. This is evidenced by the popularity of low drift amplifiertypes as well as the requests for selected low-drift op amps. However until n
  • Audio Applications of Linear Integrated Circuits
    PDF, 272 Кб, Файл опубликован: 2 май 2004
  • AN-262 Applying Dual and Quad FET Op Amps (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 май 2013
    The availability of dual and quad packaged FET op amps offers the designer all the traditional capabilitiesof FET op amps including low bias current and speed and some additional advantages. The cost-peramplifieris lower because of reduced package costs. This means that more amplifiers are available toimplement a function at a given cost making design easier. At the same time the availab
  • AN-263 Sine Wave Generation Techniques (Rev. C)
    PDF, 747 Кб, Версия: C, Файл опубликован: 22 апр 2013
    This application note describes the sine wave generation techniques to control frequency amplitude anddistortion levels.
  • AN-256 Circuitry for Inexpensive Relative Humidity Measurement (Rev. B)
    PDF, 262 Кб, Версия: B, Файл опубликован: 6 май 2013
    Of all common environmental parameters humidity is perhaps the least understood and most difficult tomeasure. The most common electronic humidity detection methods albeit highly accurate are not obviousand tend to be expensive and complex (See Box). Accurate humidity measurement is vital to a number ofdiverse areas including food processing paper and lumber production pollution monitor
  • Get More Power Out of Dual or Quad Op-Amps
    PDF, 91 Кб, Файл опубликован: 2 окт 2002
На английском языке: Datasheet Texas Instruments LM358PWR
