Datasheet Texas Instruments LM35DM — Даташит
СерияLM35
МодельLM35DM
В±0.5В°C Temperature Sensor with Analog Output with 30V Capability 8-SOIC 0 to 100
Datasheet LM35
PDF, 1.7 Мб, Версия: G, Файл опубликован: 15 авг 2016, Страниц: 36
Precision Centigrade Temperature Sensors
53 предложений от 25 поставщиков
SENSOR ANALOG 0C-100C 8SOIC. Temperature Sensor Analog, Local 0°C ~ 100°C 10mV/°C 8-SOIC. Temperature Sensors - Analog and Digital Output
Рутоника
LM35DM/NOPB
74 ₽
Microfind
LM35DM
от 135 ₽
LM35DM
LM35DM(SMD,3.5K/RL)
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаLM35DM
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLM35DM/NOPB
Replacement CodeS
InterfaceAnalog Output
Local Sensor Accuracy(Max)0.5 +/- C
Рабочий диапазон температурот -40 до 110,-55 до 150,0 до 100,0 до 70 C
Supply Current(Max)114 uA
Supply Voltage(Max)30 В
Supply Voltage(Min)4 В
RoHSSee ti.com
  • Thermocouple, Cold-Junction Compensation—Analog Approach
    PDF, 614 Кб, Файл опубликован: 27 авг 2014
    Temperature is the most commonly measured physical parameter in a variety of systems, including automotive, industrial, and consumer domains. There are various temperature transducers available to address the need of accurate temperature measurement. Thermocouples are widely popular because they are inexpensive, have a wide range, are small in size, and do not need excitation. This application not
  • AN-460 LM34/LM35 Precision Monolithic Temperature Sensors (Rev. C)
    PDF, 495 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application report discusses the details and uses of the Texas Instruments LM34 and LM35 asprecision temperature sensors.
  • AN-480 A 40 MHz Programmable Video Op Amp
    PDF, 218 Кб, Файл опубликован: 11 май 2004
  • AN-1852 Designing With pH Electrodes (Rev. A)
    PDF, 115 Кб, Версия: A, Файл опубликован: 1 май 2013
    A pH electrode measures hydrogen ion (H+) activity and produces an electrical potential or voltage. Theoperation of the pH electrode is based on the principle that an electric potential develops when two liquidsof different pH come into contact at opposite sides of a thin glass membrane. This was originallydiscovered in 1906 by Max Cremer [1]. His discovery laid the foundation for Fritz Habe
  • High-Efficiency 3A Battery Chargers Use LM2576 Regulators (Rev. B)
    PDF, 187 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes two LM2576-based designs that provide up to 3A of current for batterycharging.
  • Sensing and Monitoring for Control and Protection Seminar
    PDF, 245 Кб, Файл опубликован: 17 фев 2003
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • Semiconductors > Space & High Reliability > Sensors > Temperature Sensor
На английском языке: Datasheet Texas Instruments LM35DM
