Datasheet Semtech SC563LHULTRC — Даташит
| Производитель | Semtech |
| Серия | SC563 |
| Модель | SC563LHULTRC |
Сдвоенный 300 mA LDO стабилизатор напряжения в миниатюрном 8-выводном корпусе MLPD площадью 1.6 × 1.2 мм
SC563
Dual Output 300mA LDO Linear Regulator
POWER MANAGEMENT Features Description
The SC563 is a dual output, low dropout linear voltage regulator designed for use in battery powered applications and other applications with space constraints and low power requirements. The SC563 provides fixed output voltages up to 300mA of load current per channel. Fixed output voltages for each output eliminates the need for external feedback resistors. The device has separate input, output and enable pins for each LDO channel. Using the lowest possible input voltage for each output voltage reduces the power loss for each rail. This improves overall package thermal performance and efficiency compared to single input voltage devices. The device has fast turn-on and turn-off voltage slew rate for fast system start up and reset response. Low quiescent current extends battery life. The SC563 family of devices provide protection circuitry such as short-circuit protection, under-voltage lockout, and thermal protection to prevent device failures. Stability is maintained by using µF capacitors on the output pins. The MLPD-UT8 .6mmx.2mm package and small ceramic bypass capacitors minimize the required PCB area. Input voltage range -2.3V to 5.5V Two 300mA (maximum) outputs Dropout at 300mA load -80mV (Typ) Quiescent supply current -50A (x2) Shutdown current -00nA Output noise -00VRMS /V Over-temperature protection Short-circuit protection Under-voltage lockout Internal output discharge 00W MLPD-UT8, .6mm x .2mm x 0.6mm package Applications Consumer electronics Wearable & Portable electronics Cell phones GPS devices Set top boxes/HDTVs Communication electronics Industrial electronics Typical Application Circuit
V IN 1 V IN 1 EN1 V IN 2 EN2 C IN 1 1 µF C IN 2 1 µF OUT1 E N 1 SC563 OUT2 V IN 2 EN2 GND PAD GND C OUT1 1µF C O U T2 1uF OUT 1 OUT 2 Rev 2.0 SC563
Pin Configuration Ordering Information
Device
SC563LHULTRC()(2)
T O P V IE W Package
MLPD-UT8 .6Ч.2 Evaluation Board SC563LHEVB(3) GND OUT1 OUT2 GND 1 2 PAD 3 4 8 7 6 5 EN1 V IN 1 V IN 2 EN2 Notes: () Available in tape and reel only. A reel contains 3,000 devices. (2) Lead-free package only. Device is WEEE and RoHS compliant. (3) See the Voltage Options Table for Manufacture Part Number Voltage Options and Part Numbering
Device Ordering Number Output Voltage Options
OUT SC563LH SC563LHULTRC 3.3V OUT2 .8V MLPD-UT8; 1.6x1.2, 8 LEAD JA = 90°C/W Marking Code
LH Auto-Discharge
Yes Note: For additional Fixed Output Voltage Options, contact Semtech marketing. Marking Information 2 SC563
Absolute Maximum Ratings
VIN, VIN2 (V) -0.3 to …
- SC563LHULTRC
- Power Management ICs > Linear Regulators & Controllers
