Datasheet Texas Instruments LM5118MH/NOPB — Даташит
СерияLM5118
МодельLM5118MH/NOPB
Несинхронный повышающе-понижающий контроллер, напряжение 3–75 В, режим тока, 20-HTSSOP от -40 до 125
LM5118 Wide Voltage Range Buck-Boost Controller datasheet
PDF, 1.3 Мб, Версия: J, Файл опубликован: 30 июн 2017
Pin2020
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7373
CarrierTUBETUBE
МаркировкаLM5118MH
Width (мм)4.44.4
Length (мм)6.56.5
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Duty Cycle(Max)98 %
Iout(Max)10 A
Iq(Typ)4.5 мА
Package GroupHTSSOP
Special FeaturesEnable,Frequency Synchronization
Switch Current Limit(Min)4 A
Switching Frequency(Max)500 kHz
Switching Frequency(Min)50 kHz
TopologyBuck/Boost
ТипController
Vin(Max)75 В
Vin(Min)3 В
Vout(Max)70 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: PMLKBUCKBOOSTEVM
    TI-PMLK Buck-Boost Experiment Board using LM5118
  • Evaluation Modules & Boards: PMLKBUCKBOOSTEVMB
    TI-PMLK Buck-Boost Experiment Board using LM5118 with TI-PMLK Buck-Boost Experiment Book
  • Evaluation Modules & Boards: LM5118EVAL
    Evaluation Board for the LM5118 Wide Vin Buck-Boost Controller
  • Maintaining Output Voltage Regulation During Automotive Cold-Crank with LM5118
    PDF, 642 Кб, Файл опубликован: 27 июл 2015
    The standard 12 V automotive battery rail can vary from 9 V-16 V during normal operation depending on load and charge. Under transients conditions battery voltages can range from 3 V to nearly 65 V. One of these extreme conditions is cold-crank. Cold-crank happens when the battery is trying to energize the starter of the engine and the battery voltage plummets to 3 V. Previousl
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
Серия: LM5118 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM5118MH/NOPB
