Datasheet Texas Instruments OPA2364IDGKRG4 — Даташит
СерияOPA2364
МодельOPA2364IDGKRG4
1,8 В, высокий CMR, операционный усилитель RRIO 8-VSSOP от -40 до 125
OPAx363, OPAx364 1.8-V, 7-MHz, 90-dB CMRR, Single-Supply, Rail-to-Rail I/O Operational Amplifier datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 6 мар 2016
Package TypeDGK
Industry STD TermVSSOP
Package QTY2500
МаркировкаBHL
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Additional FeaturesShutdown
АрхитектураCMOS
CMRR(Min)74 дБ
CMRR(Typ)90 дБ
GBW(Typ)7 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)0.75 мА
Iq per channel(Typ)0.65 мА
Количество каналов2
Offset Drift(Typ)3 uV/C
Output Current(Typ)45 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)5 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)17 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2.5 мВ
  • High-Voltage Signal Conditioning for Differential ADCs
    PDF, 125 Кб, Файл опубликован: 14 июн 2004
    Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2364IDGKRG4
