Datasheet Texas Instruments OPA364AIDR — Даташит
СерияOPA364
МодельOPA364AIDR
1,8 В, высокий CMR, операционный усилитель RRIO 8-SOIC от -40 до 125
OPAx363, OPAx364 1.8-V, 7-MHz, 90-dB CMRR, Single-Supply, Rail-to-Rail I/O Operational Amplifier datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 6 мар 2016
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY250025002500
CarrierLARGE T&RLARGE T&RLARGE T&R
Маркировка364AOPA
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Additional FeaturesN/A
АрхитектураCMOS
CMRR(Min)74 дБ
CMRR(Typ)90 дБ
GBW(Typ)7 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)0.75 мА
Iq per channel(Typ)0.65 мА
Количество каналов1
Offset Drift(Typ)3 uV/C
Output Current(Typ)45 мА
Rail-to-RailIn,Out
Slew Rate(Typ)5 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)17 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2.5 мВ
  • Zero-crossover Amplifiers: Features and Benefits (Rev. A)
    PDF, 296 Кб, Версия: A, Файл опубликован: 9 фев 2017
  • High-Voltage Signal Conditioning for Low Voltage ADCs
    PDF, 135 Кб, Файл опубликован: 15 июн 2004
    Analog designers are frequently required to develop circuits that convert high-voltage signals to levels acceptable for low-voltage data converters. This paper describes several solutions for this common task using modern amplifiers and typical power supplies. Five examples of conditioning ±10V bipolar signals for low-voltage single-rail analog-to-digital converters(ADCs) are presented:
  • High-Voltage Signal Conditioning for Differential ADCs
    PDF, 125 Кб, Файл опубликован: 14 июн 2004
    Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design,
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA364AIDR
